Approximately 18 R9 290X's, actually. Not sure why you're so incredulous - I finished this (
http://imgur.com/LgWH9y6) last week and finished the second one last night. Both are currently keeping my garage quite toasty, and I've got the parts for another 2 racks on the way.
Each rack is currently running approximately 15,660 mH/s.
Sure. I just got into mining. I learn things fast, this stuff is easy. EE/ME/CE by trade.
Well, yes - I have to decide if I turn one of my racks over to AKC for half a day, or two. Decisions, decisions..
Just making sure that wasn't a typo.
I'll be honest: I haven't been keeping up terribly much on the thread here lately. There's been a lot more chaff than useful information going on, so I've only been skimming. And I generally don't click on image hosting links directly, and if images are inlined I usually don't see them especially if I'm skimming on a break while at work because most image hosts are blocked. I've actually been busy on a couple other forums between a couple other side projects and also keeping up with maintenance on the pools.
So please don't be offended... I didn't know you went "all in".
Congratz on the setup. Mighty impressive.
You're more than welcome to hop on. As of last check I know my pool has at least 40 pre-registrations. I have no idea exactly what people are bringing to the party in terms of hash rate, but hopefully we'll see blocks flying left and right.
Between 15-30? That's a HUGE difference. lol
@ SunnyD : Also would like to confirm the AKC thing. When should I point my paulty 1.4 mH at your pool.....?
Also, confirming that this is a scam coin. Don't care. It's a gamble. :biggrin:
I personally haven't heard anything directly from the coin's dev despite PM'ing them. I was sort of expecting a confirmation of some sort with at least instructions on how they're handling the wallet launch for the pools, but I'm guessing there will just be a general update and that's that.
Basically, what I'd do if you want to set up for as soon as the pool is ready is:
- Log into the pool and setup your workers beforehand
- get your cgminer (you use cgminer right?) conf file set up and ready with the pool stratum added
- set the priority for the pool to 0 and set failover to NOT disable failed pools
That way you'll happily continue mining whatever pool is next in your priority queue, but as soon as the stratum for the AKC pool comes up cgminer will detect it, test stability and within 5 minutes
should automatically switch to it and start mining given the higher priority. (I'm pretty sure you can change the stability test timeout as well, but I don't know what the parameter is off the top of my head)
And yes, it probably is a scamcoin, but aren't they all?
