Cryptocoin Mining?
Page 402 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Attic
4,282
Given most of the script-based hashing powers going towards the alternative currencies now I'm highly cautious about investing any scrypt asics. That area, alt coins, is constantly changing. Scrypt ASIC may not work well here.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Keep in mind the gridseed based asics are actually dual-mode asics - they do both SHA256 AND scrypt.
Mark R
16
The last few weeks have shown an explosion in the number algorithms being proposed and used.
Scrypt (with a higher or dynamic difficulty).
SHA3
Multi-hash multi-iteration algorithms
are all now in use in one or more coins, with more appearing rapidly.
There are other novel algorithms being proposed, such as Tromp's cyclic graph cuckoo hash. This one certainly looks interesting, but I haven't had time to think it through fully yet. The protoshares "momentum" proof-of-work, while it looks very nice on the surface hadn't really been properly thought though and is potentially vulnerable to things such as Floyd's cycle detection (or Pollard's Rho) algorithms.
That said, proof of work doesn't really have to be completely secure. Modest vulnerability is OK, it just shouldn't completely subvert the work.
geokilla
2,012
Should have jumped on Max...
It's plummeting now, but I made another .4 BTC from mining it last night till now on 2x7970 and 2x780. Don't think any other coin comes close to that return.
Still set to give me .15 BTC for today, so it's still the most profitable to mine as far as I can tell. I may go back to VTC after tomorrow though.
You can mine MAX on AMD GPUs? How?
taserbro
216
Just get the newest cgminer and add --keccak. My underclocked 290 gets more than 300Mh/s. Profitability is going down by the minute and pools get ddos'd about 10 times a day but it's still about twice as profitable as anything else.
Grooveriding
9,147
1,330
I made close to 9K in three days off Max. Best coin ever.
It's value is a 1/10 of what it was and difficulty is sky high now, but boy was it good for that first day and a half with solo mining and crazy .02 value.
geokilla
2,012
I'm surprised the coin hasn't died yet considering how crappy it is... Obvious pump and dump that no one got to work, except for NVIDIA miners.
How much would I get with my 7950 if I pool mine for a day?
Edit: Max dumped all his coins and is creating StacyCoin according to reports on Bitcointalk.
taserbro
216
Honestly, for all the people calling it a failcoin, it's made me about three times as much as I've ever made mining on two gpus for a couple days.
If it's pump and dump, then someone's not dumping hard enough because it's still making me a pretty profit even now and one 7950 actually hashes faster than two 780tis using the latest commits. Beware the scam pools though.
wand3r3r
3,180
Has the 7950 hash increased, or which commits are you talking about?
Attic
4,282
BAMT 1.5 is the first BAMT version I've used. I switched because I couldn't get more than 4 GPU's to function in Win7 and didn't have immediate access to Win8x. With Win7 I was running around 830-840 mH/s on scrypt, after installing BAMT (simply run off a flash drive) I was hitting 1005-1015 averages across all cards with the exact same config - so I'd suggest it's a Win 7/64-bit limitation.
I just redid my kitchen and swapped out a dual 40amp breaker when splitting 220 out for an island range, and still had it sitting in my server room.. so simply re-arranged some breakers and added in the previous dual 40a (total of 80a) and swing by a hardware store for a few reels of 8-3. Ran a new dedicated cable to the garage as you see in the image. Simple math told me 80a was enough to run what I need and potentially a little more.
My house is increadibly effecient. Electricity bill in the winter when gas is powering the furnace is something like $60 due to high effeciency appliances and full-house LED lighting so I didn't need to upgrade the service to run a continuous 6000w in the garage. You really only need to upgrade the service if you wire in a new breaker and find you're pulling more actual than the house on high load. I can turn every light and appliance in my house on and still barely cap 3000w so I'm good on overhead.
I'm not too handy with electrical once I get beyond replacing standard wall receptacles. But I take it you are running the dual 40amps at 120v?
I'm now considering putting my attention to the 290x instead of 280x given I've got a board capable of running 6 and that'll be my last mobo/cpu combo for sometime. I had nightmares trying to get a 290x to hash well on win7 64bit. But I'll need to revisit I think on bamt.
Got a sweet spot config you'd care to share and did ya seek out boards with Hynix mem vs elpida?
Attic
4,282
I've seen those specs but I thought they could hash one or the other, not both at same time?
I've been looking at alpha technologies 25mhs miner. But it's still 4 months out minimum I think. If these kind of things are the real deal then it will change the landscape. 25mhs for under 300w, but I think a catch 22, alt coins filled a nitch that I think initially moved away and would continue to move away from ASIC use. I see asics being tied to mining BTC. We'll see, I think there's 10-12 months before this battle has some clear indication of outcome.
taserbro
216
The latest cgminer gets me 300Mh/s by just tweaking the intensity while my 780 barely get 160M when it works on the latest cudaminer commit from github. And that's supposedly the better one that doesn't get close to 40% rejects from most pools (I still get like 10% rejects overnight).
I'm planning on just putting the 780 back on vertcoin since it's doing just as well as a 290 for that one, if not faster when overclocked at the same noise level...
T_Yamamoto
15,007
795
Dang it. I knew I should have mined Maxcoins.
Can someone teach me how to dump coins? I don't know how to pump and dump.
Grooveriding
9,147
1,330
I couldn't say exactly. I mined solo for the first two days and found my own blocks. 96 coins per blocks and I found 11 blocks in total. Made a killing right at the initial outset when a block was almost = 2 BTC. Following day a block was about = 1 BTC. Now it's about .2 BTC per block/96 coins.
Past two days I've been pool mining with 2x 780 & a 7950 since the idea of finding a block solo at this point is a pipedream. The 7950 is faster than a 780, about 300Mhash and the 780s are about 200Mhash each. Yesterday pool mining netted me about $300 worth of BTC. Today with those cards going at current difficulty/value my guess is about $100. So maybe $50 a day on a 7950 with things as they stand right now.
geokilla
2,012
You guys are so successful... I've mined for two months now and made $0 because I haven't sold any of my CATs or DOGE :'(
suklee
10
In the meantime I continue to plod along with my aged 6950 on middlecoin and still manage around 0.04-0.05 BTC/day, which is profitable for me. At the very least, there's still money to be made from all the speculation.
What's your hashrate on that 6950? I've never broken 0.04 BTC per day and I'm doing approximately 2 MH.
thilanliyan
12,059
2,272
Yeah there's no way anyone can make 0.04-0.05 BTC/day with ONE 6950 on middlecoin. I had ~4MH/s pointed at it and I was making at most about 0.07 BTC/day (exchanged). Unexchanged added about another 0.03BTC/day.
njdevilsfan87
2,342
265
Same here. I've made over 3 BTC mining it in a few days (will be at 4 BTC by tomorrow morning), and puts me at 10X mining income compared to the best scrypt. Even right now it's still like 3X more profitable to mine MAX over anything else.
With that said I still think the coin is stupid, even though I do plan to put 1 BTC back into the coin at some point (just in case someone wants to be the far greater fool than me). But just not right now as its a mine and dump coin because profit is just too favorable for the miners.
Mark R
16
Agreed. I had 5 MH/s pointed at middle coin, and it was a rare day indeed when I got 0.1 BTC.
Last few days, yield has been in the region of 0.04 - 0.05. There are greener pastures.
geokilla
2,012
I've given up. Just setting it up on MAX now. Let's see how well it is. CGWatcher is reporting over 400Mh/s. The pool isn't reporting anything though.
My configuration file:
Code:
"pools" : [
        "name" : "Maxcoin",
        "url" : "stratum+tcp://max.mining4all.eu:3332",
        "user" : "xxx.1",
        "pass" : "xxx",
        "pool-priority" : "0"
"keccak" : true,
"gpu-threads" : "1",
"intensity" : "16",
"lookup-gap" : "2",
"thread-concurrency" : "24001"
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Gridseeds can indeed mine both at once, but you do lose a bit of hashrate at least on the scrypt side.
Alpha-T imho is an outright scam. At best, they might end up like BFL, but I'm thinking they're just going to take your money and run.
wand3r3r
3,180
I couldn't get Maxcoin's wallet to sync. I can't believe how much some people made on it. I saw CPU miner and pretty much ignored it, then CudaMiner, still didn't pay attention and now I'm finally ready to hop on board for the last few minutes before it dies and I can't even get the wallet to synch. I'm done with that coin.
On a side note, I found a scipt to restart cgminer at intervals in case it has crashed while you're away.
Put on the desktop or wherever you want in e.g.
StartMiners.Bat
(remove the extra space in the path, the forum wants to make a smiley face)
:top1
E:
cd E: \pathHere\cgminer-3.7.2-windows
START mybatchfilename.bat
timeout /T 1800
taskkill /f /im "cgminer.exe"
timeout /T 10
goto top1
You can switch the path as needed, the first E: is to get CMD on the right HDD. If you use C: just remove the first line and switch the second like this.
:top1
cd C: \PathToCGminer\cgminer-3.7.2-windows
timeout /T 1800
timeout /T 10
goto top1
I haven't tested it overnight but I assume it works.
x3sphere
722
24
www.exophase.com
We got really lucky I'd say. Apparently the Windows wallet wasn't working properly at launch, only Linux users had no issues. Not having an onslaught of AMD GPUs mining the coin at launch meant less dumping too. Fortunately I had everything ready to go the day before as I was following the cudaminer thread.
A lot of people didn't even know there was a GPU miner initially, saw threads about launching CPU farms on AWS/DigitalOcean while I was mining with 500 MHash lol.
IEC
14,600
6,084
Thanks guys. I hope it's better late than never for Maxcoin, but I just joined the party with 2000 MH/s pointed at a pool.
geokilla
2,012
I can't get past ~270MH/s on my 7950. Are you running any special settings?
