Cryptocoin Mining?
Page 39 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Ares1214
268
I have a 4890, wonder if this is worth doing...Maybe could upgrade to some 5850's for this. How profitable has this been for people? I guess we all know why Nvidia's stocks have been dropping :p
Aikouka
30,383
912
That is kind of the plan...but seems overkill, haha.
If you're going to buy any new hardware, I would go with 5830s if you can find them. They have the lowest cost of entry and can perform admirably compared to its bigger brother(s).
I might need to change my username to Negative Nancy after all this, but I'm losing faith day after day in the Bitcoin market in regard to being profitable. Just watching the pools gradually rise... BTCG went from ~1.2GH to ~2.4GH over the course of one week. This severely hampers the average Joe's ability to gain bitcoins as it will only be the people that continually invest in their infrastructure that see similar rewards as more workers join.
The problem there is... they're adding more hardware (aka spending more money) simply to see the same amount of return. The worst part is that bitcoins aren't even trading for as much as they used to, so technically they're adding hardware at even less of a return considering conversion rates.
Note that some of my figures tend to come from me looking at block statistics on BTCG, which shows you how much people earned (sorted by highest BTC gained) per block. The highest person when I started earned ~1 BTC per block and the highest person now still earns ~1 BTC (around .8 it seems). Given the rise in difficulty and more people adding workers (that are in turn taking shares away), these people have to add more hardware to see the same return.
So, in short... adding hardware tends to help you "keep up with the Jones" and also keep your own level of BTC reward as the difficulty increases, but overall $/hour seems to be getting worse compared to $ invested. The worst thing as an investor is to see your ROI go down (especially considering ROI / time).
gorobei
4,098
1,603
right now its only worth mining if you already have the equipment. the cost of a custom mining rig with new multi pcie slot mb, multiple cards, and high wattage psu makes the initial outlay too big to recoup costs quickly. which means you are in for the long haul and highly dependent on bitcoin exchange rate.
some of the rackmount builds i've seen on the bitcoin forums are insane. triple 6950 boards x5 in a custom rack. multiple Ghash rates.
the real question is will everyone eventually be forced to work in pools just because the compute power has grown to big?
JSt0rm
27,399
3,948
well i was going to wait for the 7000 series from amd to upgrade my 4890 but if this thing tanks I would probably pick up a 6950 for cheap.
Feb 19, 2001
20,155
23
A 6950 is about $200... do you think you'll be able to recuperate that much money if the price doesn't bounce back? It'll probably only give you between 270-300 MHashes extra.
well either way i have a full system setup. my only cost now is to get a new graphics card.... a 6950 should repay itself decently running 24/7
Chiropteran
9,811
110
Got my newegg gift card from spendbitcoins.com The memory I was going to buy was sold out, so I went with cheaper and only got 4GB, and had to fill in with some flash drives to spend all my gift card.
ASUS Sabertooth 990FX AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Item #: N82E16813131736
Standard Return Policy
$199.99
Thermaltake Toughpower Grand TPG-850M 850W ATX 12V v2.3 & SSI EPS 12V v2.92 SLI Certified CrossFire Certified 80 PLUS GOLD ...
Item #: N82E16817153143
$219.99
$199.99
AMD Athlon II X2 265 Regor 3.3GHz Socket AM3 65W Dual-Core Desktop Processor ADX265OCGMBOX
Item #: N82E16819103910
CPU Replacement Only Return Policy
$71.99
Kingston DataTraveler 100 Generation 2 4GB USB 2.0 Flash Drive Model DT100G2/4GBZ
Item #: N82E16820139291
Memory Standard Return Policy
$7.99
Kingston DataTraveler 100 Generation 2 8GB USB 2.0 Flash Drive Model DT100G2/8GBZ
Item #: N82E16820139292
$11.99
Crucial 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model CT2KIT25664BA1339
Item #: N82E16820148262
$39.99
Subtotal $531.94
Tax $0.00
UPS Guaranteed 3 Day $15.98
Gift Card -$547.00
Order Total $0.92
This system will be used with 3X5830s I bought last time newegg had them in stock at $109. I have a myopenpc open enclosure to set it up in, and a spare mouse/keyboard somewhere, will install windows via USB so no need for an optical drive. Going to also be used as a desktop of sorts by my GF, so I decided to opt for the dual core CPU instead of a cheap sempron. Am I the only person who thinks scanning electron microscope porn when i see that CPU name? When/if bitcoin mining loses it's luster, I can add a bulldozer and turn this into my main system.
Spike
6,770
So, assuming everything comes back just fine is there any reason I should not try this? I have a 6970 in my main gaming rig sitting around doing nothing right now except when I play some games. I also have a 5870 in my lan box that is used very seldomly, only 10-12 times per year. Would it be worth setting both (or 1) up and just letting it go? We have cheap power here and my PSU's are somewhat efficient so I'm not worried on that end.
Just wondering what the down sides are. Is my PC basically useless for anything else while it's running? Can I interrupt the process without much consequence or do I need to have a pc I can dedicate to this? For that matter would my old pc with the 4870 512 thats almost never used work as well?
Thanks!
repoman0
5,191
4,574
^You can set priority with GUIminer. -f 30 in the extra flags and you will still be able to play any game you want (for less mhash/s bitmining obviously). -f 0 and it will be laggy during light use (but your mhash/s will stay very near its max).
Might as well go for it, you'll for sure end up a few bucks ahead!
Feb 19, 2001
20,155
23
Is there a need to use 64-bit OS?
Will Windows XP work fine for dual 6950s?
It's a dual core Opteron rig with only 2gb RAM, so I'd probably stay on XP, but if I need I have a Vista license I'm not using right now (yuck). If XP is ok, I'll just hop onto Newegg and buy my 6950s later tonight.
I've never messed with heavy GPUs (I'm only on a 4850 now and I had a 7800GT before), but I'm probably gonna have to get some 80mm fans for my old case which has 0 working case fans right now. The CPU will be cooled by a 120mm cooler thankfully.
dust
1,328
All the servers report normal load except for the second Netherlands server, which is high ATM.
Spike
6,770
I followed the instructions in the OP but have some issues. first off the miner program can't find my 5870, something about no opencl device detected and possibly needing to install the stream SDK? Second, I can't get the miner to start, not even on CPU, as I can't seem to find the pool I joined in the list. I just picked the pool from the OP (mining.bitcoin.cz). Any ideas?
thanks!
aka1nas
4,335
thanks!
Yes, you need to go install a video card driver with openCL support (the cats usually have a version with or without on AMD's site, and you can optionally install the Stream SDK separately).
Slush's pool is the name of the pool in question in GUIMiner.
gorobei
4,098
1,603
you need to install opencl driver. cat11.5 or higher.
as far as pools go. i mine at multiple pools just in case one has server/network issues.
https://en.bitcoin.it/wiki/Comparison_of_mining_pools
guild
deepbit
bitcoins.lc
every so often you may get one with a couple of seconds to a minute of idle or low connection and your hashrate will go lower. to make up for the gaps i mine on 3 to make sure my full rate is being used all the time. guiminer faq page has info on how to set priority on 1 pool.
Spike
6,770
Thanks for the answers, I got it working on my lanbox running at ~350Mh. I have no idea whether this speed is worth it or not but thats what I will run with for now. I game too often on my main PC to want to tie up my 6970, at least for right now.
We will see what this 5870 can net me...
