Hmm, Doge is truly a special or odd coin. I tried my best to avoid it after the initial rush thinking it was in exchange rate hell, and now I feel like a fool. Time to finally direct my hashing power back towards it....
Its foolish to sell doges before the block reward halving tbh.
I've been mining for fun (and miniscule profit) for a couple of weeks. I seem to have the bugs sorted out and my 280x can hit 280k pretty steady if the rest of the computer is idle. With a bunch of stuff open but no video going it's in the 660 - 675 range.
But when I try to play a youtube video, things get laggy and hashrate drops down to the 400kh/s range.
I'm thinking of getting a 270 to power my system and monitors for day to day work while the 280x mines. Then at night, putting the 270 to work mining as well.
I welcome any suggestions on whether that is a valid strategy and anything I need to be mindful of when setting that up, how to configure my bat files, etc. (I'm still a noob at this, but learning quickly).
Thanks.
Thanks.
Kloc, my thinking on the 270 was that I could use it for work, rendering, watching videos, etc while the 280 mines during the day. Then at night running a second .bat for the 270 so that it can put its 350 (or whatever) kh/s to work while I sleep.
I thought I heard of using the integrated graphics, I've been meaning to try it out and see if it's not laggy when at full power. My 290x's can handle higher intensities than the last gen cards for some reason but I turn it down or off if using the cards for something else.
I run off the iGPU, but you wont get sensor readings from CCC or other software, the cards function fine but you cannot tweak them for fanspeed, clockspeed or vcore.
Where is the iGPU guide again? I want to start using mine, but have no clue how to start. I control all my card settings through cg miner anyway, so I would definitely prefer to use iGPU.
Can I switch from iGPU to one of the graphics cards if I decide to run a game?
You cannot tweak it at all when you run off the iGPU.. well I cannot get it to tweak. Its all stock only.
Thanks.
Stock as in whatever is in it's bios. So you can tweak it if you modify the bios.
When I get issues on one of my rigs (I run a seperate bat file for each card) the whole thing usually goes bust.... Either cgminer just stops mining and freezes up on the current hashrate with no error message or my PC locks up/reboots because one of my cards crapped out... So I use 1 worker per PC.
I've been on both sides of the dedicated mining rig vs a productivity/entertainment/mining rig. From what you wrote I'd suggest you just take it to the logical conclusion and figure out how to build the most efficient dedicated mining rig you can. Sempron 145, 4gigs RAM, ~$100 Mobo, Gold or platinum PSU to power 3 or more GPU's.
For mining rigs with more than one card you really need an open air setup IME. I've had best response in temps from using PVC to build an open air miner. Get temps down, volts down, power use down and then run 24/7 and don't worry about it until needed.
If you want to continue the route of the 280x plus another card for which the other card will do productivity during day and mining during the night then I think the 270 is the right choice. You can undervolt the 270 to the 1025 1075 range and get ~400-430Kh/s (980/1500 core/mem, intensity 18, TC 16384). This gets power draw down to ~120watts. Asus or MSI versions.
so I've got 4 cards. Do you guys make 4 workers? It's actually easier this way for me to see which card might need tweaking.
I'm thinking if I use all 4 cards on 1 working account I would get less stale/invalid shares, does that make sense or am I off my rocker.
A Swiss company is making an ATM that can do EUR to BTC/LTC/DOGE...
May be the start of crypto "banking"
