ViviTheMage
Radeon 5000s and 6000s also support BFI_INT which makes a nice difference.
How would one utilize this in gui minter?
every so often I get stale/invalid, is that bad? can I fix that?
Just out of curiosity, why is this an AMD only game?
You can mine bitcoin using nvidia cards if you want to, but they generally don't perform on the same level as their AMD counterparts. This is due to AMD's graphics architecture which is better at this particular type of task.
Which is somewhat ironic considering how Nvidia is pushing GPGPU and how far ahead they are in that area. This task just happens to run better on AMD, though. Both architectures have their strengths and weaknesses.
By the way, I only have one hd 4770 ... should I even bother?
I'm not sure what that means or how it happens either. My GUIMiner shows 608 accepted, 4 stale/invalid. Deepbit.net shows .76% of my work as stale. I think it's normal, but I'm not 100% sure.
Ok so I set up the guiminer, set the client path, username and password and launched the "bitcoin client as a server" yada yada, and now I'm waiting for all the blocks to be downloaded.
My confusion is about how do I know when said blocks are downloaded.
This guide says there's a link I can check to see when it's done - the one with just the 6 digit number on it, but so far, after about half an hour, the number remains unchanged.
So, uh, what am I missing here?
^^^Is there a chart that shows the efficiency of each individual gpu?
Price is rising back up! Anybody else think it might be wise to not sell off ALL of your BTC right now? We are selling some, but holding to see where the price goes.
How do I connect to a different server in BTC Guild? The UK one seems to have problems.
I must say, between trading and tweaking my cards (now at 900 mhz core, 335 ram, 1.060v -> 281 Mhash) I'm seriously getting a great entertainment value per dollar out of this bitcoin game.
Switched to mining namecoins, made about 3 bitcoins in 3 days even after difficulty switch. Now it's back to picking bitpennies off the ground.
It's just like playing eve online markets in RL. Except here when I get filthy rich there will be a few $ to buy my wife flowers for putting up with my gaming obsession.
