akugami
- Feb 14, 2005
- 6,210
- 2,552
- 136
I'm paying $0.09 per kWh and am using the waste heat. Win win.
Getting pretty loud (and hot) in my office...
If you're getting repeated crashes, your stuff was broken to begin with. A video card should remain stable even if it is run at 100% utilization constantly. If cgminer crashes it, then in all likelihood other stress tests such as FurMark would do the same.
What kind of video card do you have? What cooler does it use? How is your case ventilation? Does GPU-Z show the GPU or VRMs overheating before a crash?
I didnt say it was repeated crashes. Using the default "highusage" settings for my card in the miner would cause the driver to fail every once and a while.
I'm currently enjoying free electricity, so is there any incentive to reducing voltages? Or should I max out every overclock setting available for the card?
I'd give them a call. The sapphire 290 I oredered on the 5th is on the truck for delivery as of 8am this morning. Wish I had gotten it friday but oh well.
Try cgminer 3.7.2 and the latest AMD 13.11 betas
http://ck.kolivas.org/apps/cgminer/3.7/
http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
Xpage, you have to start up cgminer through a bat file. Post one if you have it, if not, I suggest looking it up.
I had the same thing with 3.5, gave 3.7.2 a try and now I am mining! Although I don't really expect to continue, just playing around.
Hope I don't burn up my 6770 just playing aroundShould i change some settings so my card inst working so hard? Not sure whats what. Power tune was at 20 and all I could find said it was about extra voltage which didn't sound safe so i lowered it. The wiki page had the -I at 18 for my card. I changed that trying to get 3.5 to work and haven't changed it back.
thread-concurrency 8192 --lookup-gap 0 --gpu-engine 850 --gpu-memclock 1200 --gpu-powertune 5 -w 256 -I 10 -g 1
Also, How bad is 77 kH/s? How many years until I have one litecoin?
Thanks guys, turns out that cgminer 3.5 didn't like my computer, 3.7.2 did the trick. wow this was easier than i though to setup, looks like i should have done this when i first saw this thread when i had cheaper electricity. Though i am mainly doing this to heat my room as it's cold and it's either this or get a space heater.
now i am going to have to go unlock my 6950 to a 6970 as i have a dual bios with switch reference and last i checked 90% of people with my model did get a 6970 that was downgraded to a 6950.
dam pc becomes very laggy when I mine. Is this normal?
naah it's my server so I am good. Always knew that 1250W PSU wouldn't go to waste on the serverYup. If you want to use the PC while its mining, set intensity to 13-15 and its still very responsive.
1-So if i add one of my 6950 to my second picE port in my mobo. Do i have to reinstalled drivers?
2-And i take it i have to make another miner under wemineltc.com.
3-And do i have to change the Miner.bat notepad log i made under cgminer for the 290 to now account for the 6950?
Thanks guys.
Too lazy to go through hundreds of pages of posts but I got a Sapphire Vapor-X 7970 Ghz 3GB. Card runs at 1050 core, 1500 mem. Was getting in the 500's khs. Flashed BIOS using a Sapphire Dual-X BIOS. Upped the core back to 1050 and the mem back to 1500. Now getting in the 700's khs.
Used this BIOS.
Link to ATI flash utility.
Link to Rufus, a bootable USB creator.
**WARNING: Not responsible if you brick your video card.**
1. Download the Sapphire Dual-X BIOS, ATI flash utility, and Rufus USB.
2. Use Rufus and create a bootable USB stick.
3. Copy the BIOS and ATI flash utility into the USB stick you just created.
4. Boot your computer from USB stick.
5. Type in "atiflash.exe -i" without the quotes then hit return. This will show you the Device ID's of your cards.
6. To flash the BIOS, type in "atiflash.exe -f -p 0 bios.rom" and then hit return. If you have multiple GPU's installed, change "0" to the correct Device ID. Change "bios.rom" to the name of the Dual-X BIOS you just downloaded.
7. When done, reboot and your Sapphire Vapor-X should now be listed as a Dual-X.
Go into ATI CCC and you can safely boost the GPU core and mem speeds back to 1050 and 1500 respectively. Test mining. Should be in the low 700's compared to 500's before the flash.
Hope this helps someone.
**EDIT: Spelling mistakes**
Do you the sapphire 6950 2gb? I have a few that were sitting in my closet and I think I'm going to do the flash. But 90% isn't even that great a success. What I want to do is undervolt it. Trixx seems to do it but under load it still uses the max voltage.
