BallaTheFeared
- Nov 15, 2010
- 8,115
- 0
- 71
190-200 kH/s @ 150W
Woof, better shut that thing down, think of the trees man!
But in all seriousness, that is some pretty awful kh/w :thumbsup:
190-200 kH/s @ 150W
just like any market, ups and downs.
Withdrawing money is very difficult for Americans, which leads to higher prices for BTC.Is there any reason not to use Mt Gox? It seems like rates are much higher there than places like coinbase and BTC-e.
As I've said repeatedly, the power costs DO NOT MATTER if you are currently paying for electric heat. All you are doing is substituting a heater that does calculations for a heater that doesn't do calculations. The only reason NOT to mine (given above scenario) is if you are worried about wear and tear on the fan.
This is the worst day for bit coin in a while. I hope it rebounds.
Glad I took the sell as I got approach over the past 2 weeks. LiteCoin is also dropping hard right now. All coins are. This could be the big correction.
I got the below gaming rig.. Is it worth figuring out how to mine today?
Yes, if you don't mind the heat and noise 24/7.
That assumes price stays where it is and doesn't collapse and that difficulty remains constant, and given how all the stores sold out of Radeons over the holidays and how it takes a few days for things to get delivered and set up, I'd say we're in for one HELL of a difficulty bump real soon. If difficulty doubles, revenues halves.
Anyone else using Multipool? It monitors a bunch of smaller cryptocurrencies for profitability vs. BTC and switches your miner between them automatically based on which is the best at that minute. Seems like a great way to maximize profitability.
Nwo, I'm getting aobut ~380KH/s on my 7870 with 900/1450. What are your other settings? Seems like I should be more than 5KH/s faster with 200MHz more on the mem clock.
I will double check the settings on my MSI card for you tomorrow. But from my experience with 7870s, higher clock speeds may actually give you lower hash rates. For some reason GPU clock speeds do not give a linear hashrate increase like they do for the CPUs. For CPUs, I know that if I bump up the frequency by 100MHz, I will gain an extra x hashes per second... That is definitely not the case for GPUs, at least not the 7870s I have experience with.Nwo, I'm getting aobut ~380KH/s on my 7870 with 900/1450. What are your other settings? Seems like I should be more than 5KH/s faster with 200MHz more on the mem clock.
Hmm I appreciate the help offer very much! My hashrate seems a bit low, but then I have seen them all over the place on the net from 500kh/s to almost a Mh/s. Right now, just looking at GUIminer, I'm at 729 kh/s.
As of now I am running 290x core unlocked at stock speeds; the card doesn't seem to be a great OCer.
My settings are TC=32765, vectors=1, GPU threads=1, worksize=512, intensity=20.
I tried putting the extra flag lookup-gap 2, but it would fail to connect and get any work.
Also, I replaced the CGminer folder that came with the guiminer-scrypt to the latest, 3.7.2.
Used this guy's settings pretty much...https://forum.litecoin.net/index.php/topic,6842.0.html
Just an update, for all those with a 290 unlock-able or not: I was getting issues with mining as a 290x, so I went back to stock bios. Now, not only does it seem more stable, but I get higher hash rate! Using the same settings, I get around 820 kh/s. Not sure if this was due to core instability, or if for some reason 290s do better right now than the 290x.
Its because mining thrashes these GPU much more than gaming, causing massive power spikes which means Powertune kicks in and throttle clocks. A R290X on auto settings with its extra shaders are going to consume much more power so it will throttle. You can try your R290X bios with +50% powertune and 100% fan speed (temporary) to test and see the clock speed during mining.
