Cryptocoin Mining?
Page 22 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
NoStateofMind
9,711
You don't even need to do that. Basically, your wallet balance is all in the block chain. You could setup your wallet once, get a send address, and then copy it to a CD-R or something, delete it from your computer. You could receive BTC from mining at 1.5/day for months, years even, to that address. Whenever you install the BTC client and use your original key you will see your full current balance, just like magic.
Then what stops someone from taking your address and plugging it into their own? Theres something I/we are missing here. Wallet.dat?
YoungGun21
2,546
Ok I'm going to answer a lot of questions here.
@ghost recon 88 GUIminer is your best bet. I use it on one machine. It is a front end interface that has several different miners available. I would suggest running a phoenix miner for the 5870 and a poclbm miner for the 6950.
@chihlidog and Aikouka There will be variances between blocks. One may take 4 hours. The next may take 4 minutes. It is even over time. (I remember one block Slush pool found in 1 second, I didn't even get any shares!)
@ImDonly1 Estimated means your estimated return for the current block. Confirmed is all of your returns that have been confirmed by the network, unconfirmed are the more recent ones that have not yet been confirmed. Also, always running the client when you have a pool isn't required, but the wallet HAS to be open when the pool sends you BTC. That's why I would just leave it open. Once the initial block chain is downloaded, it uses hardly any resources at all, so it shouldn't be a problem.
@Drivenbyvoltage I would not suggest setting the threshold to 5+. Most people won't even get that in a week. Especially not after the impending difficulty increase (sometime tomorrow). This is also bad because if your pool holds all of your BTC, if you need to sell quickly your are screwed. The best place for your BTC is your own personal wallet on your computer. We have our send threshold set to 2, but we get that fairly quickly because we are netting ~1.2 per day.
Also, how about that projected increase? 50% eh...
muskie32
3,115
7
Has anyone been able to buy anything with these bitcoins? If so I would put together a dedicated box for them (most likely a SR-2 filled with AMD GPU's)
NoStateofMind
9,711
No major e/retailers accept them at this point (that I'm aware of). You would have to transfer your BitCoins into another account in order to buy something.
https://mtgox.com/
If you plan on filling all those SR2 PCIe slots on that motherboard you are going to need dummy plugs and PCIe ribbon extensions.
YoungGun21
2,546
We bought our extension cables with BTC. Typically though we just convert to USD and put it in a bank account. We've made a couple hundred USD thus far, and we are sitting on a couple hundred more. Should have all hardware paid off within two weeks if the price stays above $15.
Chiropteran
9,811
110
The wallet.dat has your private key. Anyone with your private key can access your bitcoins, that is the thing you must keep secure.
I don't think that is true.
For example, see here:
http://webcache.googleusercontent.c...d=1&hl=en&ct=clnk&gl=us&source=www.google.com
When you send bitcoins to an address, it basically just adds them to the block chain saying "hey, I belong to the guy who has <THIS> private key" It doesn't matter if that guy is running his bitcoin client or not, because the block chain is saved forever. You can log in 5 years later, download the block chain, and your client will recognize each transaction that is unlocked with it's private key. No need for it to be online when the transaction occurs.
hdfxst
851
5830 back in stock at newegg but 7.56 shipping
edit: free shipping,thanks PC
note235
1,502
7
bought!
thanks!
6970x1
6950x1
5830x2
that should work...lol
note235
1,502
7
props to you! :)
btw ok so i haven't bought the 6970 YET. right now i have a
6950 1gb
5830 1gb x2
thinking about getting another 6950 1gb for $200 or buying a 6970 2gb for $275?
If i add the 6970, how would I calculate my total power consumption?
thanks!
Auric
9,591
Even though phoenix-phatk has a higher hash rate it produces significant stale/invalid such that the result is little to no net gain. So, I've just returned to standard pobclm.
A net gain is actually only possible at most intensive settings (thus invalids not due to overworking) and even then is at best 1.5%.
243 Mhash/s -v -w 128 -f 1
255 Mhash/s -k phatk AGGRESSION=11 BFI_INT VECTORS FASTLOOP=false
4.9% gross gain
3.4% invalid (with pobclm negligible >1% so may even be more stale than invalids)
Aikouka
30,383
912
I'm tempted, but I think I'm more worried about the looming difficulty increase just destroying the possible profitability. Right now, I'm just using hardware that I already own, so it's really just the extra electricity. I'm also a bit worried that the DDoS attacks are slowing down generation... so we're not even operating at full potential anyway.
I gave away a lot of my old hardware ( motherboards and such ), but I could probably easily toss one of these into my main PC, another into my other PC, two into my "server" and one into my HTPC (at least that's downstairs where it's significantly cooler :p). But that's about $550 which is around 27 Bitcoins. Assuming I can pull around 300 MHashes/s (each) with those cards, I would be adding 200&#37; more power (I do around 750 MHashes/s right now). So it'd probably take around a month to make back what I spent and that's at the current difficulty level.
YoungGun21
2,546
4.9% gross gain
Some people have problems with phoenix giving a lot of stales, but we haven't had that trouble.
YoungGun21
2,546
Yea you'll need plugs and possibly extension cables. I'm not familiar with the port setup on that. There are guides on the Bitcoin forums on how to setup headless rigs.
It is possible to run without the plugs if you just have one card in each computer, but obviously that isn't what you are doing.
