What's the best performance/cost card these days? Does the 7790 crank out a disproportionate amount due to GCN 1.1?
I've gone from earning 0.1 to 0.08 coins per day with the latest difficulty jump. Not gonna be able to hold out too much longer without more price increases! Go BTC, go!
I wonder how the LTC to BTC profit ratio will look after this change.
AM3+ works with Phenom II right?
How many GPU's can I run off this board?
http://www.newegg.com/Product/Produc...82E16813128514
Says "Up to 2 VGA cards are supported" I'm assuming in CF/SLI, but since I don't plan to CF/SLI anything, will that effect weather the boards x4 lanes pick up any additional cards?
Supported CPU
CPU Socket Type
AM3+
CPU Type
FX / Phenom II / Athlon II / Sempron 100 Series
FSB
2600MHz Hyper Transport (5200 MT/s)
The 3rd slot should accept a video card no problem, it's physical 16X and electrically 4X - Don't expect a ton of Bandwidth, but you shouldn't lose much at the same time with another 7950.
It will be fine. x1 is enough bandwidth for mining.
Should be fine with up to 3 dual slot cards. I have the UD7 and while I could run 4 cards, the temps were just too high...ended up selling my other 6950.
I haven't mined in months. Would it be worth it to mine with a 7950 on colder days?
At 550Mh/s, at the current difficulty level, how many hours would it take to forge a bitcoin?It's about $3.5/day for bitcoins (550Mh/s). $4.5/day for litcoins (500kh/s). More if you overclock - these are just rough estimates.
I can't find any PCIe extenders, at least none with molex... I assume since these aren't quality multi gpu boards like ws revo I had with molex/pcie connectors on the board I'd want the molex version...
Ah well![]()
and they run cool enough to add into most rigs without worrying about cooling capacity
Is anyone else here mining Feathercoins? I'm racking up a pile of them pretty quickly, and they're starting to show up on the currency exchanges now.
