I think I'd smell burnt pcb if I tried for those settings, that one of those extra nice cooling models?
Hmm, something isn't right, i have an account set up with BTC Guild, workers set up properly.
Problem 1: Using the following settings is giving me 5-6 MHASH/s which is awful.
Problem 2: Every time i try to enable the BFI_INT argument it instantly crashes to desktop after opening.
I am using Phoenix with this string of arguments.
(slow)
C:\phoenix-1.48\phoenix.exe -u http://username:pass@btcguild.com:8332/ -k poclbm DEVICE=1 VECTORS AGGRESSION=5
(crashes to desktop)
C:\phoenix-1.48\phoenix.exe -u http://username:pass@btcguild.com:8332/ -k poclbm DEVICE=1 VECTORS AGGRESSION=5 BFI_INT
Edit: It appears to be using the CPU and not the 6850. All 8 threads are running 96-100%. Kind of amazing i didn't notice any stalls in general usage while this is running.
Bitcoin difficulty is based on the amount of computing in the peer group correct? If so wouldn't it cycle around an equilibrium point based on the currently available hardware? If difficulty jumps up to the point that someone with a single Radeon gpu only gets 0.2 Bitcoins every week or longer then they are likely to drop out of the network entirely. As more of those people stop mining the difficulty level would adjust downward until it entices those people to get back in and the difficulty climbs again.
I've been thinking about the exact same thing. In that situation, will the difficulty decrease?
That's something I'd like to hear from someone knowledgeable, does it decrease or just not grow as quickly? Is the difficulty purely based on the length of the chain? If so it would just stagnate and you wouldn't see small miners come back in until you get quite a leap in individual GPU hashing power.
DEVICE=1 is prob your CPU. Try DEVICE=0.
ATOT folks join the simplecoin.us pool. Its open source and free to use!
I've tried. Registration doesn't work for me. it says account created, and then won't work saying wrong password.
Slush's giving good returns, anyway.
So am I a fool for not jumping on the Bit coining mining? Gear in sig, I been planning to buy a 6950 anyhow...
