I have to admit that I'm intrigued by the jalapeno but in the long run I expect it to have a negative impact on BTC, it's value will likely be massacred.
So are you thinking GPU mining is dead around October then?
Ya, I am undecided about those ASICs simply because of ETA. If they come on-line in large volumes in October, then it's probably the end for GPU mining due a huge rise in difficulty (much like CPU mining was killed off). At least that leaves a bit more time for people to pay off their AMD hardware or a part of it. But I think the greatest fear I have is people with 2 original singles will just upgrade to the new Mini-Rigs for free. That's like going from 1.6 GHash/sec to 40 GHash/sec! At the current difficulty rate, 40,000 Mash/sec = $5,500 USD / month. At those rates that's just 1.5 weeks or so to repay back the Mini-rig. Everyone in this thread would just buy 1 in that case. That likely means the difficulty will skyrocket soon.
You incessant cheerleading of mining isn't helping. Difficulty is rising 10% week over week. Even without ASIC mining, that kind of pace will result in difficulty increasing 50% in just one month's time, and more than doubling by October. The last thing we need is more miners.
Not necessarily dead, but after ASIC units IMO it will mutate into something ugly with deflated value and shrunken user base, eventually becoming a niche hobby, hardly a profitable one. I mean, Jalapeno introduction will be like pitting a Athlon vs i7 and expecting the Athlon to look good.
If GPU mining become unprofitable though, wouldn't GPU users who didn't get the ASIC drop out? That would leave people holding ASICs at least some initial profitability, I guess unless you expect a ton of people to grab $150 Jalapenos. It's so hard to say what will happen but I am leaning more towards your side which is why I haven't ordered an ASIC yet. Others think bitcoin mining prices will rise to compensate for the exponential increase in difficulty rate.
From what I understand the biggest danger is bitcoin currency collapsing in value after ASIC introduction. If dedicated ASICs render GPU mining obsolete, suddenly the PC people will have very little reason to use bitcoin currency - it's impossible to mine using GPU and it is too inconvenient to use as a valid form of payment still. This will substantially reduce bitcoin user base, less demand for the bitcoin currency means it's going to be valued less relative to the $.
BitCoin however is not like either exactly, its based entirely on the difficulty in "printing" more money. Having no actual use besides being a currency it lacks one of the stabilizing factors of precious metals. And being math based, a creative improvement in mining technology is not only plausible but inevitable, and whenever one occurs you suffer market upheaval and inflation.
There will be a brief production increase, right as the ASIC hardware comes online, but with the next difficulty adjustment it will be right back where it was.
It's important to realize that block generation is not a long, set problem (like doing a million hashes), but more like a lottery. Each hash basically gives you a random number between 0 and the maximum value of a 256-bit number (which is huge). If your hash is below the target, then you win. If not, you increment the nonce (completely changing the hash) and try again.
Alternative asset classes are used to combat the inflation and insecurity caused by governments just printing out more and more fiat money.
Precious metal coins have actual use (industry and jewelry) as well as a finite quantity on earth and limited rate of mining. So inflation is possible, but so is deflation as population can grow faster then total reserves.
Which is WORSE not better. A one time inflation followed by stability is less harmful.
During that brief production increase, only a select portion of the population will see an increase, and when the difficulty is adjusted, only they will still be able to generate any at all. So its the same total amount being generated, but now its ONLY being generated by those with ASICs, in essence they perform two seizures.
1. Seize existing funds (via temporary inflation reducing the value of their competitors coins)
2. Seize production of new funds (via rendering production on GPUs impossible).
They are both.Precious metals are an asset class, not a currency.
That's just silly, different currencies inflate at a different rate. A currency can even undergo deflation while another goes inflation. And currencies value relative to each other constantly fluctuates.You can't really use other currencies to combat inflation since all world's currencies deflate vs. the cost of goods and services
None, which I have clearly stated when I explained its a fiat currency.What use does US dollar have other than being a currency?
With the exception of currencies which have additional value sources.Currency by itself has no value other than what the market assigns to it.
All in all, the increase in total hash isn't going to be much different from the increase that occurred when the first GPU miners became popular and CPU mining died off. The end result back then was BTC going from being worth pennies to being worth dollars. It certainly didn't cause any inflation, it caused the exact opposite.
I know Jalapenos are backlogged, but what about the new Singles, anyone ordering them that know if the shipments are on schedule?
