cusideabelincoln
It's definitely the power supply. 24A on the +12V rail is not enough for two HD4850s (which need about 110W each under 3D load), although a single one should work perfectly fine.
Your cards have to share the same +12V rail (which probably also has your optical drives and hard drives and maybe even motherboard on it). 24A is the limit for one of the 12V rails. You are probably exceeding this limit, and thus the OCP built into the PSU is shutting down the computer to prevent it from frying. This is a good thing, as no components should be damaged by a failing PSU. Although a lot of PSUs usually allow for greater amperage than the stated limit.
You'll want to get a quality power supply, and make sure it can deliver at least 33A on the +12V rails combined. This should equate to about a 600W PSU, or as F1shF4t said 550-650W. If you want suggestions, look into the Antec Earthwatt series, any Corsair, any PC Power & Cooling, OCZ ModXStream Pro series, or any 80 Plus Seasonic.
