Critique my website
ChrisIsBored
3,400
Get rid of the subdomains... it's loading new images every page and that's slowing down the experience.
Also your test page has errors...
Barnaby W. Füi
12,343
Originally posted by: sandmanwake
What's wrong with Frontpage? I've tried dreamweaver and it's just too complicated to use for me.
I care not about the user interface, I care about the absolute garbage markup and "code" it creates.
dquan97
12,010
I don't think the subdomains are the problem. I deleted the subdomains and the same lag occurs.
GtPrOjEcTX
10,784
what are the files sizes of those pictures...I tried to save as to figure it out but only save option is bitmap for some reason.
also getting an error message on line 43 whatever that may be.
Barnaby W. Füi
12,343
The lag occurs because the browser has to load the image *right that instant* when you hover over it, and it simply can't do it that fast, it takes time to transfer. Make something that preloads the images with height and width of 0 and stick them in a corner or whatever. It's messy but then again so is javascript.
The subdomains make no sense, generally you make a subdomain for a totally different site, and use subdirectories to organize content on one site. Your pages all essentially link to totally different sites, it's just now how websites should be done.
GtPrOjEcTX
10,784
nah, javascripts a lot less messy than what you are suggesting about the images IMO.
take that out of the body, investigate the image sizes...
dquan97
12,010
they are 10KB each. If anyone wants to try to upload the site to their webhost to test the rollovers, I can zip the entire site and host it.
ChrisIsBored
3,400
Subdirectories are part of your problem.
Let me guess.. you have 5 seperate folders...
Home - Pictures - Schedules - Links - Contact
Now in each of those folders you have your Image directory. Each page a user visits is loading images from a new Image folder. We're downloading the images 5 times to see the whole site.
You need to either get rid of the subdirectories, or link to a single image folder. That will help some as far as load times go.
Now for preloading... add this inside your head
<SCRIPT language=JavaScript>
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a.indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}
</SCRIPT>
Then in your body add the following
onload="MM_preloadImages('images/top_img1.gif','images/top_img2.gif','images/top_img3.gif')"
dquan97
12,010
same results: Here
dquan97
12,010
Each time a user visits the index.html page, the images for the nav bar is pulled from a single images directory on the main folder. When a user goes to the accompanying sites, then the nav bar images are pulled from the images directory in the subdomain.
I'll post the downloadable zip file of my site here
ChrisIsBored
3,400
You shouldn't do it that way.
They're not seperate sites... they're supposed to be seperate pages. In those pages... if you're convinced on using the subdirectories... why don't you just link your images either like this:
../images/image_file.gif
or give it the direct URL like this:
www.davidquan.com/images/image_file.gif
It makes absolutely no sense to have the same images in different subdirectories unless you plan on them looking differently... otherwise it just uses more of your bandwidth, and takes longer for users to view your site.
AmdInside
1,355
Is it me or is the site very slow?
I have pretty cool actions (Photoshop) for frames if you want to post pictures. I can email it to you. I used DreamweaverMX to do my website:
My Website
What company is hositng your site?
ed21x
5,411
8
Originally posted by: BingBongWongFooey
Originally posted by: Deslocke
Also you might consider using frames.
For the LOVE OF GOD, NO!
Anyways, change the navigation bar button text to be more readable, and preload the navigation bar hover images (so it doesnt delay when you hover over them), other than that it looks very nice.
Actually I'll add another vote for the frames, this way you don't have to reload the top navigation bar all the time, and will really speed up the overall site.
here's a sad example
yoda291
5,079
my 2 cents,
On the design side,
-Your whitespace isn't being used to it's full potential, everything is crowded into the upper left corner, even at a 800x600. Spread it out or even centering the content a bit would help I think.
-Your font is a tad on the small side, especially considering it sits amidst a sea of black.
-Your navigation is slow and load times are disproportionately high. Also, the rollover images don't always load up, I get red x's half the time
On the technical side,
-Recommend flash(if you have it) for the navigation instead of Javascript. It's not so complex that loading in the flash player will kill render time.
-Do you really need "background=images/bg.gif"? Also, I can tell your background is white because it only seems to draw the background up to the content, then stops using opera.
-kill the subdomains, most hosts will set up subdomains as subfolders anyways.
On the personal side:
-consider appending a '/' to directory links, it used to be used to reduce stress a tad on servers but it's kinda old fashioned (read: unnecessary), but I find html is easier to read with it there.
-please don't use frontpage.
dquan97
12,010
Thanks for the suggestions, all! I'll take up ChrisIsBored's suggestion and put all the images on the main directory, since I want to keep the subdomains (and the <><)
Any of you guys have personal sites that you are proud of and that I can visit?
MeanMeosh
3,805
ok, I tried everything to get the rollovers to work properly. See my test site. It still lags...
I have Dixiesys as my webhost.
may i suggest loading those images when the webpage loads for the firstime? cant remember the exact tags, but i've used it before... this way, there's not even the slightest lag time for onmouseovers
Use two types of fonts - SansSerif for Headings, Serif for Body text.
My $0.02 worth
BingO
dquan97
12,010
I've used three different way to preload the images, but they all had the same lag effect. Could the image size of 5KB be the reason? ( I dont think so)
