Creative X-Fi Xtreme Audio 24-bit Sound Card
dileepsv
185
hey..all
i was planning to connect my sound card to the home theatre system..(sony dream system) it has both coaxial in and optical in...what cable should i use?...does it have the outputs for them..if anyone knows about this sound card or has it..please tel me wat exactly i would need to get along with the cable...??
Thankyou!! :D
PurdueRy
13,837
4
Originally posted by: montypythizzle
Eh, you should have got the XtremeMusic, or something in the X-Fi line besides the XtremeAudio.
won't matter when using just the digital coax out.
montypythizzle
3,698
Oh, yeah, I just told some guy that a few days ago must have been under the influence of the Internet when writing that.
Tiamat
14,068
True, in that case, the Chaintech card for 20$ might have been a 'better' choice...
montypythizzle
3,698
Newegg no longer sells the AV710 :(
Yeah, some guy made fun of onboard audio with TOSLINK out, heh, told him it didn't matter.
I did notice more bass and treble when going from onboard optical out to the AV710 optical out, and WAY more difference with the headphone out. However now the AV710 is just bit-perfect out with the digital.
dileepsv
185
so...should i just buy a Digital Coaxial cable to connect this sound card to my home theater? i dont need nething else?? wats the best site to buy it..?
PurdueRy
13,837
4
Originally posted by: dileepsv
nope...more from music
then just get a 3.5mm to RCA converter from radioshack and a digital coax or composite video cable to go to the receiver.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Yeah, reason I was asking is because the X-Fi cards will not get you surround sound for games through a digital connection.
http://forums.anandtech.com/me...1=digital+audio+thread
Since that's not a priority for you, then this should work fine :thumbsup:
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
http://www.soundblaster.com/pr...tegory=16&product=1780
How is that?? Digital Coaxial or Digital Optical ???
You could use that, but you could alternatively get a generic cable that's cheaper and just does the one conversion you need. I don't know where you could get it in Canada.
The converter just needs to take 1/8" (3.5mm) and change that into an RCA connection so you can plug it into a receiver.
I don't remember if you specifically need a mono 3.5mm to single RCA or if a stereo 3.5mm to dual RCA for the creative cards. I know on a TBSC that a stereo adapter will work.
dileepsv
185
ok i got wat u ment by 3.5 mm to RCA converter cable... why do i need digital coax/composite video cable?? don't the RCA red and white cables go into the red and white audio inputs on my home theatre receiver already?
PurdueRy
13,837
4
The converter is about 3/4" long. You need another cable to go from that converter to your receiver. A composite video cable and a digital coax cable are identical(both 75ohm cables). So that is what you need to run to your receiver.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
If you want to connect to the Red/White analog inputs on your receiver, you'll only get stereo sound from the computer from music an movies. You'll also be connecting to the analog audio output of your soundcard.
If you want to connect digitally, you'll connect to the digital output of your soundcard and then you'll need to change the output connection so that you can plug it into the digital coaxial input on your receiver (a single RCA connection)
To do this, you can either get a long cable with the appropriate connection types at each end (3.5mm and RCA) or you can just get a small adapter and then use a digital coax/composite video cable to connect from that adapter to your receiver.
For example, you could use
https://www.cablesforless.com/...=VIEWPROD&ProdID=13729
and then you'd need to plug in a single RCA cable to the adapter and then run the other end to your receiver's digital coaxial input.
Before you buy anything though, we should make sure that a stereo 3.5mm connection to 2xRCA will give you a digital coaxial signal on one of the RCA connections. It worked on a different card for me, but I don't remember if Creative did something with their connection so that only a mono 3.5mm connection to 1xRCA will work.
PurdueRy
13,837
4
<a target=_blank class=ftalternatingbarlinklarge href="https://www.cablesforless.com/index.asp?PageAction=VIEWPROD&ProdID=13729">https://www.cablesforless.c......WPROD&ProdID=13729</a>
Back when I had a Audigy 2 ZS either would work. I used a 3.5mm mono to RCA adapter. $3.99 for the nickel plated version....$4.99 for the gold plated version at Radioshack.
