I am having trouble getting my Creative 3D Annilator 2 to work w/DIABLO II (although DIablo doesn't need 3d , when i enable it after the video test, the screen goes black after i try to enter the game.
Yes i also downloaded the new drivers, the nvidia direct3d drivers...unreal tournament (requires 3d) works, but strangely DIablo II does not.
Should i just run diablo II with 2d ?
I am worried if this might happen to my other 3d games.
Are there any test i can do? Thanks for ur help guyz!
my system:
WIndows 2000 Prof.
512 MUSHkin high performance
2 ibm 45gigs
1.2athlon
3d annihilator 2
creative sound blaster live 5.1 platinum.
cable modem
my system:
WIndows 2000 Prof.
2 ibm 45gigs
1.2athlon
3d annihilator 2
cable modem
