rbV5
- Dec 10, 2000
- 12,632
- 0
- 0
Have you tried capturing video other than from your VCR? It may help if you try some simple captures from another source (for instance the AIW's tuner) so that you can get a feel for the workflow of the various applications you are using.
Try doing small captures off the tuner with MMC at different settings/codecs. Then try using VirtualDub to capture, or encode some of your other captures.
its a method used to keep you from copying copywritten source material.i don't know what Macrovision copy protection is
