- May 11, 2008
- 20,136
- 1,149
- 126
This is a more traditional setup, the integrators are no longer connected in series with each other as in the previous schematic. This improves stability.
Now i have created an analog or port. The opamp with the lowest output voltage wins by making use of blocking diodes. Of course, the opamps outputs can now no longer source current, only sink current. To solve that issue, i have added a 12mA current source. The transistor Q5 will be a different model. Because in worst case scenario it has to dissipate around 400mW of heat. I need a transistor there that can handle that. The output stage transistors i have to change to different models as well. The output will be the MJ4502. But i will need a 60V VCE, NPN transistor with a fair amount of HFE gain . Because the 12mA current has to be amplified to a maximum of about 5A at least. But i would rather go for a 7.5A. To have a little headroom.
That is a total HFE gain of about 625. Now the HFE of the Sziklai darlington transistor is the product of the gain of the MJ4502 and the NPN transistor. If i can get the HFE of the NPN transistor to be between 50 and 100, i should be set. The HFE of the MJ4502 is between 25 and 100 at 7.5A. A higher total HFE gain will put less stress on Q5.
The opamp circuit no longer needs the -5V because the opamps are rail to rail output opamps. And the opamps will get a separate stabilized 32 to 33V supply. The control circuitry will be much more stable this way.
The toroidal transformer will supply the output transistors with voltage.
