Craftsman 254 piece tool set with case for $94.97!
houe
316
I called up 3 sears stores. Two of them priced it at $269 and one had it at $149. None of the stores had it in stock. I presume since its a clearance item it never will come into stock again. Was the $94 a price mistake?
RideFree
3,433
Was just at the nearest Sears in Denver.
Associate stated that they had -1 in stock (he theorized one was on BO). I had him call two or three other stores in the area and there was not one available.
However, he said that they were due in, as they were to be in the Vets Day three day sales event this weekend. :D:D:D
I did not ask for a price check.
funboy6942
15,368
418
Originally posted by: MiataPaul
Craftsman tools are not really all that great, but the cool thing is that Sears is great about replacing them. That is the main reason most of my tools are Craftsman. I bought a Kobalt socket (deep 19MM 6point for my old Mercedes lug nuts) and it cracked. Lowe's no longer stock the socket and could not give me another one. I had read that Snap On makes Kobalt tools, not sure if that is true, but Lowe's returns on tools sucks. At Sears you take the broken tool in and they give you another one. I had an 1/2 inch drive socket wrench that I bought on clearance at least 15 years ago for like $12, but at the time it was there top end ratchet wrench. I dropped it in the snow early one winter and it got plowed into the snow bank and it sat there all winter till spring thaw when I found it all rusted an locked up. It had a worn cam anyway, but I took it back and they gave me a new $40 ratchet no questions asked. Even if they have to break open a set they will replace whatever you break, even if it is obvious it was your fault, can't beat that. Home Depot's Husky tools used to be good too, but they are now made in China or some other Asian country, where ever will make them the cheapest. They now make you call an 800 number to get get replacements, not very helpful if you have your car on jack-stands and need to get it back together to go to work on Monday! End of tool rant.
I may be wrong but I want to say when I was a mechanic I heard that Snap on and the craftmans line were made at the same plant, Snap on. I have broken snap on, mac, and craftsmans tools. But I always tried to buy at sears myself because I didnt have to wait for the truck to pull in to get a replacement. Just drive down on my lunch break and swap tools and be back in busness ;)
Armitage
Banned
Feb 23, 2001
8,086
I stopped at the store in Colorado Springs tonight. Didn't see anything. Will check back tomorrow a.m. if its supposed to be a veterans day thing.
Frodolives
2,190
The deep discounts on nice sets of Craftsman tools still come along, but less frequently than they used to, and Sears seems to be pushing more and more of the "other than Craftsman" stuff, meaning without the lifetime warranty too.
When you can get a set you like for half price or thereabouts, it's not to be scoffed at. I used to work as a full service mechanic, and at least half of my tools were Craftsman. The quality is decent and consistent, and where they fall short, the replacement policy is tops.
I remember getting the run around from a Snap-On vendor for weeks or months on a couple of items, whereas Sears has yet to fail me for having a replacement item in stock.
RideFree
3,433
I've seen Sears replace crap with Craftsman and it wasn't even theirs, originally. Now, that's a replacement policy!
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
I have aset almost exactly like that. To be honest, I got it because of the toolbax it came with. The set I used to carry in my truck made tons of noise as I drove and I figured that would be better with the blow molded case.
Noise wise, it was a win. 75-80% quieter. However, the toolbox itself was a pain to open. You had to really tug on the drawers to get one open, and doing so would make the sockets fly all over when it opened. I took the drawers out and modified the detents so it would be easier to open. Then it alright. However, durring the winder I noticed another problem. The drawers do not have weep or drain holes. Durring the winter snow had blown into the bedbox in my truck, and worked its way into the toolbox. The snow then melted in the box. The water had nowhere to go, so the sockets all rusted from sitting in water for 4 months before I found the problem. I was able to clean up the sockets on my buffer and got the rust off, but it was still a pain. In other words, don't put te toolbox where it could get wet :p
I love Craftsman BTW. Best bang for the buck by far. Are they the best? Nope. That distinction is for Snap-On among others. However, the Craftsman set is ~$100 the Snap-On is $350. Same warranty, roughly the same streanth. Snap on is usually polished so it looks better, but that makes it harder to hold on t with greasy hands. Make your own decision, but it is Craftsman for me, and odds are, it is the best for you.
<edit>
ok, my keyboard is totaly on the fritz. I swear I was pushing the right keys. Time for a new one.
Cdubneeddeal
7,473
Nice tool set. I'mma have to stop by Sears this weekend to check it out. I like that they have metrics in 1/2 drive.
Yreka
4,084
I remember when I was in highshool ( 90's) I snapped the 1/2" chuck off my dad's craftsman breaker bar he got when he was in highshool (60's). Sears replaced it on the spot. I remember that damn thing was so old it didnt even look close to the part I got back from their new stock.
Anyway, not bad after 30ish years.
misterj
882
<edit>
craftsman is definitely fine for most people. snapon has two main advantages:
1. stronger, but like you said, not by a lot. in a professional setting, that risk is too high.
2. most importantly, the tolerance and accuracy. snapon tools will be more precisely measured, thus fitting the bolt more snugly, thus less likely to strip it. they will also grab on to bolts that are already slightly stripped by less accurate sockets like craftsman.
99% of my sockets and wrenches are craftsman. only a select few choice tools i use often are higher quality, i.e. matco swivel sockets and bluepoint (snapon) ratcheting wrenches.
Yreka
4,084
Truth is, that you probably had a 10' cheater pipe on that bar more than once. . .:D
It was actually 6', but yeah ;)
Broke it trying to loosen a stubborn axle nut.
RideFree
3,433
I have ¾" drive (& the 6' pipe) for those projects where the impact wrench will not do the job.
Whiskyboy
156
Thanks OP, heading out to my local Sears hoping to find one.
I checked the Vets Day ad online and they have a 244-pc set on sale for $199, no mention of this killer deal. Item number from the Ad is #34244
Cheers
Armitage
Banned
Feb 23, 2001
8,086
OP got a killer deal - the guy @ my sears said they haven't had the 254 piece kit in for some time. The 263 is on sale tomorrow for $199
misterj
882
btw i got my 254piece (no case) for 149$ a few years ago on the day after thanksgiving sale. reg $249
oh ya and my friend has this case, and it is indeed a pain to open. when working on the car, i just leave them open.
BatmanNate
12,444
I have pretty much this exact set, this is a nice deal. The plastic box is plenty sturdy, however the drawers stick a little too hard and can be a pain to pull open when your hands are covered in 10w30. I've busted quite a few of the sockets, but the breaker bar may have been involved and Sears asked no questions. :D
Frodolives
2,190
On the subject of the plastic tool boxes. I have a couple of them. One a "current" 4 drawer type, and one an older model 3 drawer.
The only problem I have with the current set is the top drawer 1/4" drive stuff that flops around all the time lol. It's still been pretty handy for hauling around. The older style box is guaranteed for any of the socket sets to make a mess whenever I give the drawer a good tug.
Either one makes a decent organizer in a shop setting. If you find that the sockets don't stay in place, maybe you have space for a narrow shelf under a work bench for just leaving the drawers out of the box in an open tray style.
MiataPaul
189
Originally posted by: misterj
very good set and deal. however, if you know you're going to be working mainly on an import or domestic car, it would be wise to just get an entirely metric set for imports, or entirely SAE set for domestics. i use metric sockets 99.99% of the time, so the SAE ones are just a waste of money and space.
Actally since the early 80's most of domestic cars use metric on most of the parts. At least the GM crap I have worked on was mostly metric.
IgoByte
4,765
Went to Sears today and they had a 254 piece set left over but it was 200 something bucks... :(
