Crack in Microwave Door, will this expedite my death?
lxskllr
60,588
10,946
My microwave interferes with wireless comms. Dunno what that ultimately means, but I assume it's leaking something. Probably uranium.
malabo
Banned
Jan 5, 2016
61
im told that microwaves dont give off the ionizing type radiation that causes cancers so i think your ok
Jeff7
41,596
20
I don't know if I've ever been around a microwave that didn't screw with wireless comms.
Parents' microwave, the microwave at work, college dorm, college apartment, college apartment neighbors, hotel rooms, or the one I have now. Any of those would disrupt wireless signals while they're running.
At home, if I've got my wireless headphones on and am within a few feet of the microwave, the signal starts distorting. Elsewhere, the disruption is visible in Task Manager: Network transfers get slower as the speed becomes erratic. The transceivers have to retry more packets to get through the noise.
On a similar topic, I've always been genuinely curious- how do you die if you microwave a human being? (or a baby)
The waves penetrate right inside, right? Would you die rather quickly (under 2 mins) since the smallest change in temp inside the brain will cause severe damage?
Or
It would take some time (2 to 5++ minutes) because you simply need to heat up your entire mass? (similar to oven where heat needs to work outside from your skin)
Heating damage, I'd imagine.:D You should poke yourself with a fork a few times first so you don't blow up everywhere.
I remember that Consumer Reports did a leakage test with microwaves by holding a small fluorescent light tube near the door. If it's leaking the tube will glow (a surprising number did back in the day).
My parents have a Quasar brand microwave.
There's something about that choice of name though.....you know, since quasars are galaxy-sized things that are the most powerful radiation emitters in the Universe.
Getting hit in the head with a dead blow hammer doesn't cause cancer from ionizing radiation either, but it's still not necessarily safe.
