Sorry (not sorry) to reply to an ancient thread but just thought I'd share my Covid-lockdown adventure
I had an old Acer X3400 kicking around so decided to use it as the basis of a new desktop PC build - a cheap way to see if I still remember how!
Firstly I transplanted the motherboard in to a Corsair 750D case - cavernous!
I had the Athlon II x4 635 (100w) model - I did the bios update and installed the Phenom II x6 1100t (125w - eBay £80).
At the same time I added a cheap 600w power supply (Amazon £40) and a Corsair H45 watercooler (Amazon £50) - this made an annoying quiet ticking noise when mounted on the top, so I moved it to the rear exhaust instead.
I also swapped out some old 1033mhz RAM to 8gb 1333mhz (£20) - they actually sent me 16gb worth but it can only use 8gb.
I'd already put a 240gb Kingston SSD in (SATA-2 / 300 limit on the motherboard) - Windows 10 activation linked to my Microsoft account.
I've used Windows 10 soft-raid to stripe a 1tb and the original 600gb HDD to give me a faster 1.2tb "storage" drive (noting the risk of one drive failing and killing the combined set).
Hadn't realised earlier that the motherboard has four SATA connectors - may install a DVD/Blu-ray writer.
And to finish...
I've got a Palit Geforce 1050 TI 4gb graphics card in the post (£50 Facebook) - replacing a low profile 1gb ATI graphics card I had in the original case.
I'm also taking a punt on a a PCIE x1 NVME m2 SSD adapter (£20 Amazon) and a Kingston A2000 240gb SSD (£50 Amazon) - not sure this will be bootable though but 2000MB/s is worth a risk (knowing the PCIE 2.0 bus will be the limit)!
I did put a USB 3.0 adapter with internal 19-pin header in the motherboard's x1 slot in order to feed the case's front USB 3 port, but I'll sacrifice this for the NVME if it is bootable. I've seen a cable to convert the 19pin USB3 header to a 9pin USB2 - there's a couple spare headers on the motherboard.
Wish me luck!
p.s. this was a useful reference:
