CPU temp lower than motherboard temp and HUGE VOLTAGE PROBLEM
slag
10,473
P4P800 motherboard, my cpu temp shows as 21c at idle, 28c full load with ambient motherboard temp at 29C
This is with the ASUS Probe software with a SP-94 and 90 mm Thermaltake fan.
To contrast, with my IC7, temps were 20 degrees higher or so with a Zalman.
It also shows my CPU Voltage as being at 1.696 whereas AIDA 32 shows it at 1.65 and the bios shows it at 1.575
HOLY COW DUNG.. I have set my voltage as low as it can go in the bios--1.525 volts, and AIDA32 shows it as 1.6 volts and ASUS PROBE shows it as 1.632 volts. Is my power supply defective, or is this a motherboard problem? That doesnt seem right! Sandra shows as 1.63 volts as well.. ARRGH
Joe
mechBgon
Oct 31, 1999
30,699
Haha, someone is believing Asus Probe! :D
Sorry slag, but get out your digital multimeter and do a reality check. ;) Asus Probe = teh
Soulkeeper
6,735
155
i would suspect that either the software or the bios is reading the temps wrong
you got a good heatsink there so i wouldn't worry too much about it tho
maybe someone that owns that board can recommend slag something ??
good luck
Budman
Asus boards always overvolt at idle & show cpu temps a bit lower than other boards.
What does it read in the bios itself?
slag
10,473
I wouldnt know where on this board to do a voltage check with my handy dandy volt meter.
myocardia
9,291
30
Hah, didn't we tell you the Thermalright's would give you lower temps?:D
mechBgon
Oct 31, 1999
30,699
The ATX cable is your target. :)
THUGSROOK
11,847
welcome to the "asus vs abit" debate.
(vcore and temps)
where have you been? ;)
asus 1.525v = abit 1.575v
asus temps = add 10*C
abit temps = subtract 10*C
RalfHutter
3,202
Thugs is correct. You should add about 8-10°C to the CPU temp reading that you get from this Asus board. I use MBM5 and add the compensation there.
The mobo temp also seems to run about 2-3°C too warm on this board. I suspect the sensor is too close to something hot like the NB or the DIMM slots, or it's tucked away in some out-of-the-airflow location.
