ShintaiDK
- Apr 22, 2012
- 20,378
- 145
- 106
Before, I only had Comcast in my area. It was great, I had highspeed internet. However, I had constant dips in my connection due to Comcast not having enough throughput for everyone. Then, this magical thing called competition came to my area. Verizon came with a FIOS line.
Now?
I have amazing throughput with Verizon, and Comcast has also upgraded their lines in the area MULTIPLE times with Verizon also upping their speeds to provide a "competitive" rate/speed to the "competition".
I can't believe you'd seriously advocate against competition.....
You confuse competition with normal infrastructure upgrades/rollout. Also again, competition doesnt magically solve it.
Let me give you an example. In Denmark we now had fiber rollout the last ~15 years. However only around 40% of the population got access to fiber today. And thats with HEAVY competition and bankrupt companies due to the harsh competition and power companies putting countless billions into fiber as well. Not to mention the access is very uneven distribution. Its really bad economics to put fiber in the ground as the only thing. You do it instead when other infrastructure needs update. Sewers, district heating/cooling, power etc.
Also just because you got fiber doesnt mean you get a better product. Fiber here even with the 40% is quite unused. Only around 30% of those with fiber access use it. The rest is still on pstn copper or cable. Hell, I even have fiber in my home but I use cable instead.
Let me show you the map of how it looks with the coverage degree in %.
People simply forget the economics behind. And just sit back and demand x product because they feel entitled for it. The same thing applies to CPUs in this thread. Because people look back on old days and then demand the same thing today. Because how hard can it be?
In the case of economics. Your ISP also need to upgrade the rest of the backbone and equipment. And while you may demand x faster product. If the rest doesnt do it in your area to make the business case, then you have to wait for more natural replacement cycles. In the US its also different since you have no access to other networks. So the infrastructure cost is much higher than other countries since each company needs its own network. And the payback on these investments are usually in the 20-30 years range. So if you want fiberrollout to everyone, then competition with multiple networks is a really bad thing.
