CPU Speed not recognized
Joels
27
Hi,
I have an AMD Athlon T-bird 1.33Ghz CPU and an ASUS A7V133 motherboard. The motherboard is set to JumperFree mode.
On the initial boot-up screen it says: AMD Athlon 1000 Mhz Processor.
Does anyone know why it does not recognize my processor as being 1333Mhz?
Should I change anything in the BIOS settings to make it recognize my processor?
Should I set the jumper setting manually on the motherboard? If so, should it be set at 100Mhz or 133Mhz?
Thanks in advance for any help.
Yzzim
11,990
<< Should I set the jumper setting manually on the motherboard? If so, should it be set at 100Mhz or 133Mhz? >>
133MHz.
Multiplyer = 10
FSB = 133MHz
10 x 133MHz = 1333 Mhz
If the FSB is only set to 100MHz you'll get this
10 x 100MHz = 1000 MHz
