CPU running slow on battery - is this normal/common?
VirtualLarry
56,587
10,225
I recently obtained an Asus X401A (purchased at BestBuy). It has a B970 CPU. (2.3Ghz Sandy Bridge Pentium dual-core.)
I installed CPU-Z 1.62.something.
I noticed, and marvelled at, the fact that while on Skype, this CPU appeared to be "so fast", that it was not even coming out of idle clocks.
Then I went to Speedtest.net, and it loaded SLOWLY. VERY SLOWLY. It's a fairly heavy flash-based site.
Then I realized, it wasn't that the CPU wasn't deciding to throttle up, rather, it was PREVENTED from throttling up.
Then I realized, that this CPU appears to be "locked" at 800Mhz while on battery. Thus being slower than my C-60 based Netbook, amazingly enough.
All, just to have comparable battery life to the c-60 while on battery.
Even Aero Glass effects are disabled while on battery.
It is using the default installation of Asus pre-loaded software. It seems to have included some sort of "PowerGears" software, that changes power plans automagically, based on whether it is running off of battery or plugged into AC power.
This feels almost like false advertising to me. "2.3Ghz" should be capable of actually RUNNING at that speed, whether on battery or not.
AMD laptops run at full-speed on battery, why can't Intel-based laptops?
I once owned a Gateway C2D laptop, that acted the same way. I think that it was 1.6Ghz, but only ran at 800Mhz on battery as well. And that was with a fresh default install of the OS. I assumed that was controlled by the BIOS somehow.
paul878
874
If you want the cpu to run full speed on battery then set it to do so in power manager. pick the Maximum performance plan.
cl-scott
ASUS Support
Jul 5, 2012
457
In short, yes. This is really more of a Windows thing than an Asus thing, but basically the CPU and other things are "degraded" in order to prolong the amount of time you can run the unit on battery power.
Ketchup
14,559
248
So Larry, if you take off the Asus crap will it start hitting full speed?
My Lenovos did not have this issue.
-Mike
marcplante
687
9
Or you can go into that Asus junk and refine the advanced power settings to tweak CPU levels under battery operation. You have to decide what profiles you want handy and whether the default windows tools give you enough flexibility to do what you want.
If so, Ditch the Asus SW. If not, you may want it
VirtualLarry
56,587
10,225
I adjusted max processor state to 100% in the Asus software, and clicked "Save", and it still doesn't throttle up when on battery power.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
As was stated earlier in the thread: check power options
It's a windows thing, not an Asus thing. You can usually get to it from just right clicking the battery icon in your toolbar, but you can always get to it via control panel. You can easily switch between profiles that control what performance is possible on battery.
Ketchup
14,559
248
I thought the 'insert power options' overrode the windows power options; so, save the Asus options = save the Windows options (that are already present, anyway)
Gooberlx2
15,381
Last few generations of CPU only really throttle up when they need to based on the task. Start compressing some HD video and then see what your CPU reports.
