I have read this thread a few times in the past (some very good info) and was finally prompted to register with the forum to share a link to an article with LLC testing with an oscilloscope,
Load Line Calibration and You'.
*Warning - article spoiler below*
Bobnova said:
Conclusion:
If you have a decent quality motherboard LLC is a good thing, and not likely to cause any issues at all.
Also, some of the comments after the article make some very valid points.
I do a lot of strenuous oc stability testing at high vcore & high clock speed with LLC enabled (worst case scenario) and it seems that you are most likely to do the CPU damage from a voltage spike immediately after the stress test has finished.
bcsizemo describes what I believe is the potential 'LLC issue'...
bcsizemo said:
Part of where the spike could come from is that time lapse between the cpu going from full load to light load in a matter of cpu cycles. Now if that really happened then the cpu PSU (the switch mode parts you are testing) would have a cycle time much longer and potentially supply a dangerous voltage.
If this outlines the potential LLC problem then what is the governing force that attempts to stop this happening?
bcsizemo said:
I would think that a large part of this issue might deal more with the feedback circuit than the actual regulation itself. Most of the capacitors and inductors are sized to meet a goal load/regulation requirement. The capacitors would need to store enough juice to be able to go from light to heavy load quickly, but that size should be able to handle ripple in the sub 1 volt category easily.
I'd suspect if this issue is ever verified I would think the likely cause would be a poorly implemented feedback circuit...
So, in summary, a poor performing PSU (with lax tolerance/poor switching) coupled with a motherboard with cheaper components (or should I say being setup in a way that it's unable to compensate for the ringing in the feedback loop with LLC enabled) whilst running variable CPU load tests is the recipe for disaster.
Anyone wanna try kill a CPU? :biggrin:
Used sensibly LLC seems to be quite safe - even at moderately high voltages (i.e. 1.45V to 1.50V for 45nm Core 2 Duos) assuming you a have good quality PSU and motherboard (and your cooling is up to the task).
So
if the spiking is a non-issue - we only have to worry about electromigration (and yes I realise that this test was run once by one person using one scope and one motherboard etc and really does need to be replicated for proof).
