CPU or Motherboard Failure? -Need Help
imported_Thrust
My PC was running fine, for months, no overclock. Then, the network device stopped working while playing a game (integrated Nvidia, Nforce 3). No matter what I tried, I couldn't get the network back up. So, I reinstalled Windows...didn't fix the problem. Following advice from Epox, I manually set the MAC address for the Network device in the BIOS. The screen flashed red, then re-booted with the MAC address re-set to "auto". However, the network then worked fine.
Two days later, the sound stopped working (integrated Realteck 805). The same thing was happening as for the network device: Control panel tells me that there is no audio device installed. Re-installing the driver didn't help. Re-installing Windows, then driver didn't help. This was accompanied by a muted tone coming from the Mobo, a two-tone cycle, high-low, high-low, that persisted even after restart (only turning machine completely off got it to stop. The tones were not as loud as a system "beep" during strat up, maybe a fifth as loud and with static. No error were reported on the LED on the Mobo.
I thought something may have overheated, so I ran SpeedFan to get temperatures. They were all fine, lower than the maximums I had seen while gaming. However, the monitor for the CPU temp (Temp2 in speedfan) was reporting a dip to 0-2 deg C every 5 secs or so. It kept repeating, 45, 46, 45, 45, 0, 45, 45, 2, 45, 46, 45, 45, 1... etc. I have never seen this before.
What I need help with: (1) Is the motherboard pooched and incorrectly reporting CPU temps and Audio device status or..
(2) is the CPU damaged and mis-communicating with the motherboard?
The PC runs fine in every other aspect except sound, so I think something died on the motherboard (perhaps related to the Network going out too).
Is there a utility or series of steps I could take to see which part I need to replace? I don't have access to other components to swap in and out. I can afford a new Mobo or CPU, but I would like to know what died.
Any help is appreciated.
-T
Sorry, I forgot specs:
Mobo: EPOX 8KDA3+
integrated Network and Audio
CPU: Athlon 3400+
PSU: Antec True Power 430
Ram: 2 X 512 OCZ low latency PC3400
Video: Gainward 6800 GT
Nothing OC'd (except the GT of the Gainward)
Update:
I tried to flash/update the Bios with the Magic Flash utility that came with the Mobo. I get an error when I select the Bios file telling me that the Bios file size does not match the motherboard bios size. I think I am on to something here as this never happened before. Is there a way to force the BIOS update?
If its Epox, I would carefully check for leaking or bulging capacitors. I have a 8RDA+ which would do all kinds of strange things and then wouldn't POST. Found out that there were many leaking/bulging caps, and fortunately was covered Epox's two year warranty. They repaired it and sent it back in two weeks though.
Here's what's going on: I cannot update the BIOS. I suspect I have the wrong version installed. I get an error about a BIOS lock string size not matching.
I went into BIOS, Disabled the Realtek audio. Restarted.
Then uninstalled the realteck driver.
Then went in to the registry and uninstalled every reference to realtek. One item called "friendly" kept re-appearing, oh well.
I went back into BIOS, re-activated the Realtek Device. BAM! Bad boot to blank screen with muted buzzer sound, restarted again after full power off, and it booted to Windows.
I reinstalled the Realtek Audio from the EPOX CD, it went fine. I now have audio!
I am still unable to update/replace BIOS. Should I power off and move jumper to reset the CMOS? What problems can this cause? I DO NOT have a floppy drive.
