Decided to do some slight upgrading and bought a new cpu and mobo.
-cpu is AMD Phenom X4 (9750)
-mobo is ASRock A770DE+ AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard
(http://www.newegg.com/Product/Produc...82E16813157226)
After putting together, computer wont start. It doesn't go past POST. I am able to access BIOS and change settings so mobo isn't dead. All pins are intact on cpu and was a brand new unit. This leads me to think its a compatibility issue.
Is my cpu compatible with this board?
The am3/am2+/am2 may have confused me.
Some clarification on this would be a great help, Thanks!
