I am currently building my first PC. I am having a problem installing an E8500 into a evga 750i FTW motherboard. My problem is clamping the socket shield. It  seems to require alot more pressure than I expected. Should the socket shield be able to close all the way on its own? It looks like the opening in the socket shield doesn't quite clear the edge of the cpu that is farthest from the hinge.
I know the cpu is oriented correctly, since the little notches make it impossible to screw that part up. And yes, I removed the black plastic protector from the cpu. Am I doing something wrong, or does it actually require that much pressure? Thanks in advance.
 Facebook
Facebook Twitter
Twitter
