- Nov 4, 2013
- 6
- 0
- 0
Hi everyone, I have always thought that GPU heatsinks are, well, a little inefficient. The air can't properly 'flow' anywhere, and they're noisy, small, and really a bit restricted simply because of where GPUs fit in a case. D:
With this in mind, I decided to do some experiments to find a better way of cooling the thing, and this is what I came up with...
The temps are INSANE!
CPU cooler on GPU - YouTube
The PLAN is that I make a compartment for the GPU that's basically like a wind tunnel with a fan at each end.
This card's TDP is 170w, so I think it'll easily work for something like a GTX 680 etc.
Please review the AnandTech Forum Guidelines:
http://forums.anandtech.com/showthread.php?t=60552
5) Spamming will not be permitted. On topic references to your personal commercial matters are permitted on a limited basis and at moderator discretion. Multiple quick nef posts, posts designed to generate traffic to specific web sites, and flooding the Forums will not be tolerated.
You're allowed to have a link in your signature, however.
-- stahlhart
-- stahlhart
