retab12332
Regarding these two coolers, Alpine 12 and Alpine CO, one uses fluid dynamic bearing while the other uses dual ball bearing, respectively. Which one is better?
I said that a fan from a quality manufacturer will last a long time regardless if it's FDB, rifle, ball bearing, etc.Are you saying fluid dynamic bearing is better than dual ball bearing ?
Are you saying fluid dynamic bearing is better than dual ball bearing ?Ball bearings typically last longer, but are also often noisier than other kinds (FDB, rifle, etc).
However, both if both are from a quality manufacturer, both should last a long time (long enough to not really worry about it).
O I see, but which one of those, would you recommend?I said that a fan from a quality manufacturer will last a long time regardless if it's FDB, rifle, ball bearing, etc.
Neither of those coolers are what I would consider budget options (basically like a stock Intel cooler), and they both have 6 year warranties from Arctic, so I wouldn't put too much thought in which one to buy.
OMG, I can't say it any clearer.O I see, but which one of those, would you recommend?
