RussianSensation
- Sep 5, 2003
- 19,458
- 765
- 126
#1: YES, ALL MODERN GAMES ARE CPU LIMITED.
#2: CPU limited is NOT the same thing as CPU bottlenecked. (Ie. if substituting a faster graphics card with the same CPU results in a greater performance increase from a GPU change, the game is GPU bottlenecked not CPU bottlenecked. It can still be CPU limited in that you can get margin performance gains with a faster cpu had it been available, but not substantial gains). Providing examples at lower resolutions such as 1920x1200 on a 4870 X2 example is irrelevant since the card was released for 2560x1600 today. In tomorrow's games it'll become GPU limited at lower resolutions.
#3: Driver scaling factors into overall performance scaling and it is often impossible to separate CPU limitation vs. poor driver scaling until many versions of drivers have been released and results updated (hindsight).
On a Quad Core 3.0ghz system the results are as follows:
COD4 2560x1600 4AA/16AF
4870 = 44.4
4870 X2 = 83.6 (+88%)
HLF2 ET 2560x1600 4AA/16AF
4870 = 50.8
4870 X2 = 85.3 (+68%)
ET: QW 2560x1600 4AA/16AF
4870 = 65.2
4870 X2 = 100.7 (+54%)
Crysis 1920x1200 4AA/16AF
4870 = 18.5
4870 X2 = 24.6 (+33%) <-- a game known for poor SLI and CF scaling.
Assassin's Creed - 2560x1600 4AA
4870 = 41.8
4870 X2 = 53.8 (+29%)
Race Driver GRID - 2560x1600 4AA
GTX 280 = 42.1 (no data for 4870)
4870 X2 = 94.1 (+124% advantage)
#4 None of the above tested games at the forementioned tested settings and resolutions will run faster with C2Q 4.0ghz and a single 4870 vs. a C2Q 3.0ghz and 4870 X2. Therefore, the only question is depending on the games and resolutions one plays, are those gains worth the expense of $550 4870 X2 vs. $250 4870? That depends on the person.
To say it's not sufficient to utilitize the card to its "full" (100%) potential would be correct. But to0 be claim that C2Q 4.0ghz is inadequate for 4870X2 (i.e. saying that 4870X2 is not worth it to upgrade because the CPU is too slow to utilize such card) is just ignorance and depends entirely on the person. The benchmarks clearly show a large gain in a lot of games.
4870 = 44.4
4870 = 50.8
4870 = 65.2
4870 = 18.5
4870 = 41.8
