that's SLI. the gtx570 is beating the crap out of a single gtx460.
This is my first time with a "nice" video card since I had a 9800pro (just to give an idea).
I am running way above ultra settings with a heavily tweaked INI file. I may have gone a bit overboard tho.
I'm running at 1080 with 16x AF.
I'm running it with vsync and 8x supersampling if that is what you were asking.
I just dropped it to 2x supersampling and it only went up to 30-35 FPS.
Are there any major performance killers I should check/change?
iPresentinterval=0
Add that to the Skyrim.ini file then check again
Turn AA dOWN to X4. Are you running it on 1080p?
Turn off vsync in the control panel. Seriously.I put it on "low" setting and while I do get 60 FPS, it's not rock solid and it randomly drops to 30 FPS....
Today, vsync should not suffer from the issue that fps drop to 1/1, 1/2, 1/3... of 60. This is not the problem as DX apparently support render ahead and the game most likely supports triple buffering. I see all kinds of fps, not just 60, 30, 20...
Backup your ini files, delete both and let the game recreate them. Restore the profile in NV Inspector to it's default state. Then go step by step applying your tweaks and settings and see what happens. No other way.
8xSGSSAA is too much for one GTX580 in 1080p. Even for GTX580 SLI it is very very taxing. Also the game can be very CPU bound.
Download MSI Afterburner or EVGA Precision and use the OSD to display GPU usage while playing. If it's below 99% when the drop occurs, it is your CPU.
You don't have to do that (reinstall that is). Wait a sec, maybe I can help you. Can you explain exactly when/how these dips occur?
Is it when you're turning?
Is it happening when you're just standing still and not moving at all?
Please upload your savegame where this happens, so I can test it. I will disable SLI and then our configs will be similar. What driver version are you using? 285.79?
Probably intentional. Letting cards render hundreds of fps on these sorts of screens causes video card whine and general stress.1) is on the loading screen, it seems to be limited to 31 fps which doesnt make sense and it is only rendering a simple object.
Yes but the game has to call for it. If the game doesn't call for it then it wont be used then you have to do the work around with d3doverriderToday, vsync should not suffer from the issue that fps drop to 1/1, 1/2, 1/3... of 60. This is not the problem as DX apparently support render ahead and the game most likely supports triple buffering. I see all kinds of fps, not just 60, 30, 20...
You're welcome. Out of curiosity: What speed did your CPU run at? Should be 3800 MHz, otherwise I would be utterly baffled.
I guess all the NPCs, objects and such tax the CPU.
Yeah I'm running at 3800 MHz. It's amazing to me, the i7 920 is such a great chip... I guess it is starting to show its age?
