For that $$, why don't you just buy a Ferrari instead?
Not to mention a 3x 480 + your system is going to require a 1200W or higher PSU (if the rumors are true). That is one hell of an energy draining system!
I was just showing that a core i7 @ 3.7 will push 2 5970's easy, therefore the GPU is the bottleneck. That was the op's question.😀
Except I used 5970's instead of gtx 480's
Well, I got myself an i7 920 with a P6T Deluxe V2 (the eVGA one was out of stock). Managed to overclock it from 2.6Ghz to 3.15Ghz using the cooler that came out of the box.
You are aware that P6T isnt even a true 3x16 board right?
Wait...isn't vdroop supposed to be good? lol There was a post awhile back that argued such.
I am not sure, but it might have an issue with turbo throttle at load.
Also, what is the vdroop like on that board? UD5 seems to have a fair amount, even with LLC enabled.
That goes beyond my expertise, what exactly is vdroop? I can tell you that CPUz reports my core voltage being v1.208 volts..
Prime95Hmm, what's a good free program that I can use to strain all cores at once?
