I'm starting to run at higher voltage on my p3 now and the temp has gone from 31C at default 700mhz to 950mhz @ 1.75v with temps running at 36C for the cpu and 32C for the motherboard at idle. The CPU runs up to about 42 under stress. I'm thinking about seeing if this CPU can do 1ghz..but i'm not sure how much is too much. A lot of people have increased voltage to 1.8-1.85, but I don't know how hot their cpu is running at now.
BTW, how accurate is the temperature monitor on motherboards? I'm running on an Asus CUSL2 and using the Asus Probe monitoring software that came with the board. Are these temps below/above/accurate to the real temp??
