- Apr 24, 2003
- 29
- 0
- 0
I got a couple of questions.
I just recently bought a Gigabyte 8knxp motherboard and so far I like it. I also bought an Intel 2.8 GHZ (533 FSB) processor. I got the motherboard to run and I left all the settings in the BIOS set to AUTO. I don't plan on overclocking at this time, but may do that down the road. In the BIOS there is a section for Frequency/Voltage Control and under there there is a line that says CPU Host Frequency (MHZ). When I look at it, it reads 100. I think, but not positive that the CPU Clock Ratio is 21x. That line doesn't show up in the BIOS, as it is shown in the manual, but I think I saw the 21x somewhere. My questions is the FSB running at 400, 533 or 800 MHZ? How can I tell what the FSB is running at? I will be installed the OS and the other utilities over the weekend. Memory shows 333. Also when I boot up, the system is seeing the 2.8 and reading it as a 2.8. Also CPU temperature is 43C
Second question, is that I also bought a Thermaltake Xaser III v1000a and I really like this case. It comes with the fan speed controlers and a probe that is suppose to connect to the bottom side of the processor. Well the probe is so big that I can't place it on the bottom. I tried it on the top and it caused the CPU to heat up to 75C or higher. So I took it off and have placed it on the heat sink. Now when I look at the bottom number on the display for temperature, it gives me one of two readings. One is like LLL and the other is just dashes. I'm wondering if the probe is too dirty from the tape that I used or if that is telling me that something isn't connected correct? Also if the probe needs to be cleaned, what do you suggest I clean it with and then where to put the probe so that I can get a CPU temperature reading.
Thanks for the help
Thanks for the help
