Counter-Stirke and Auto-Aiming
VIAN
6,575
There is an option under options/mouse that allows you to enable auto-aiming. This gives you a very decent advantage. Given the conditions that my score was 0 and 15, when I enable it, I killed 3 people easily before I died. I consider this a cheat. Many people they say that are hardcore and are the best, those with amazing scores, could they be using this legal cheat? Should it be cut from the game? I think so, what do you think?
Tetsuo
10,908
13
I think you tricked yourself into thinking you were good :p
But just like the above two guys said, autoaim = disabled in multiplayer
JeremiahTheGreat
552
unless someone turned it back on without telling... been in a game where somehow they changed the server so everyones hit box was the size of a truck. Shoot anywhere and you kill someone..
Salamandar
188
Not True, autoaim works while playin' MM.
I play Counter Strike on LAN each day. I don't usually enable autoaim (YEs I'm very good at FPS games) but when I enable autoaim I get too much head shots !
Mitzi
3,775
It CAN work when playing multiplayer but I think you'd be hard pressed to find an Internet server with it enabled.
VIAN, I think you had a case of the 'placebo' (sp???) effect..give a person with illness xxx a simple vitamin tablet saying its a revolutionary new tablet which will cure their illness and and many people will say they feel better!
VIAN
6,575
If it doesn't work then why does steam have the option for it. It might have been the placebo effect, but thats a hell of an effect.
Matthias99
8,808
It works *if it's enabled on the server*, which usually it is not. They can enable cheats, too, but again, most don't.
leetnewt
163
Simply, if autoaim is on, everyone can use autoaim, so therefore no one has any advantage over it. And like everyone says, its the servers preference to turn cheats on or off. I know cause i use to run a dedicated cs server.
If you really want to cheat, go d/l some hacks.
Jan 31, 2002
40,819
Should you do that, I'm coming to your house to bust up your NIC into little bitty pieces and then forcefeeding it to you. :|
/hates L33t h4x0r do0dZ
- M4H
stardust
1,282
- M4H
i second that... u better exercize ur colon because an AK is going up there
leetnewt
163
- M4H
LOL...I got computer nerds talkin tough over the net.....heres my address 84-seagram Drive. Waterloo, ON. Come when you want.
Evdawg
979
rofl... ive been playing this game since beta 7.. 3 years, theres no such thing as auto aim unless u install hax.... u just got lucky on 3 kills i guess =P
edmundoab
3,223
www.facebook.com
been playing it since beta 4, until it was CS 1.1
and then I just quit the game for good,... was getting too stale unless I had a bunch of friends playing that game.. in the same server.
wasn't very good myself.. and the auto -aim..
neh... never works
loads of cheaters who type codes into console though.. and they are like so happy getting frags..
Jan 31, 2002
40,819
- M4H
Since I don't go to UofW any longer, I'll have to pass - but I'll send you a free 8-pack of AAs for your Humour, Sarcasm, and Common Sense detectors. :p
- M4H
