Core i7 920 @ ?
MChim
46
Nailed it.. 3.8ghz and rock stable. 12 hours I ran Prime95 on LARGE FTT. I used RealTemp 2.70 to record temp of the cores. Max I hit was 87C on one core but when I checked it, the core was sitting at 84-85C. Stopped Prime and had no errors whatsoever. My setup:
Core i7 920 @ 3.8ghz (1.35V)
-BLCK FREQ: 190
-DRAM BUS Voltage: 1.64V
Patriot Viper DDR3 1600 (Running @ 1523mhz)
Asus P6T Deluxe
Antec True Power Trio w/3 12V Rails
MSI GeForce GTX 260 OC
NOCTUA NH-U12P Special Edition (Very Massive - Had to drill holes into the side door of the case and reposition the fans.)
RAIDMAX Smilodon (2 Custom Placed Air Intake Fans - 1 on video card, other in front of Noctua intake)
Western Digital Caviar Black 7200rpm 32mb cache
Razer Lycosa
Razer Lachesis
exar333
8,518
8
Originally posted by: dajeepster
I work part-time at teh microcenter in rockville. We have the coolermaster V8... it's better than the stock cooler... that's all I know... i'm putting one on my i920 tomorrow... right now my i920 runs at 70C stock under full load (i.e. seti on all cores) with the stock cooler... i'll give an update as soon as I get the new cooler on tomorrow.
70C running Seti seems high - even for the stock cooler. Is that at stock speeds as well?
In my experience, Seti/Folding never really tax your system the same way 8 threads of Prime95, OOCT, or Intelliburn does. I would probably assume the temps would be >70 if you tested of these other programs for a few hours instead.
BonzaiDuck
16,889
2,206
I've got the Noctua installed for an over-clocked E8600.
On the thermal-resistance issue -- the best single index of performance I know of -- it beats the TRUE and some other high-end heatpipes.
The copper version of the TRUE is too heavy, but shows some comparable performance. This CM V8 mentioned above is also showing good performance stats, but I haven't seen enough reviews.
It's possible to get the socket1366 bracket-kit for the Noctua for around $10, although it looked as though the maker was selling them for a ridiculously high price.
anindrew
219
Hi everybody! This thread inspired me to purchase the Noctua U12P SE1366 for the i7 920 system I ordered last night. I hope I have as much luck as you have with OCing.
Did any of you install the cooler into an Antec 900 case? Do you think it will fit in that case without issue?
JMapleton
4,179
Originally posted by: Dadofamunky
Here in Silicon Valley, Central Computers pretty much has everything - the CPUs, every mobo, every available cooler, and even 1366 adapters for $13.95. The new boards look gorgeous. Just Google them. Their site may not be fully updated, but their local Sunnyvale storefront is decked to the nines. Almost makes me want to do another new build, but my wife would kill me. Plus, I don't really need it.
How competitive are their instore prices compared with NewEgg?
SolMiester
5,330
17
Originally posted by: palladium
Man I really envy you guys who live in the US, here in New Zealand computer hardware is overpriced to the extent that sometimes it is cheaper to have Dell to build your system instead. But yeah.. I'm gonna get a Core i7 920 ( maybe 940 after reading aigomorla's thread sometime ago...) to replace my P4 ( reminds me of a guy in this forum - can't remember his name). Too bad O/C is out of the story because I couldn't find any local stores that sell aftermarket i7 coolers and also it's summer here and the temp in my room in the day can hit 25 deg C.
LOL...yeah, +1 on that....however P4 is damn ancient!
bryanW1995
11,144
32
Originally posted by: Idontcare
Originally posted by: MarcVenice
I envy you people :( I'm always one step behind hehe, I just upgraded to C2D/X48 :p
For me the word envy fails to fully capture the emotion I have in regards to the hardware these folks are getting to play with at the moment. :(
My best rig at the moment is a B3 stepping QX6700 (65nm) on an X38 mobo. My e-peen is so weak and flaccid these days, am having those high-school feelings of inadequacy all over again :eek:
Must...resist...urge...to...tap...kids...college...fund...to...upgrade.......again...
you can always get more kids, but you'll never have a better chance to fix your epeen...:evil:
MChim
46
You might have to reposition the fan on the door. There's a chance it will clear it. The Noctua is well worth it though. That thing is a beast of a cooler.
AdamK47
3,638
I decided to bump the voltage from 1.30V to 1.35V and try for 3.8GHz. So far it's been 100% stable. I've passed 8 threads of Prime95 for 12 hours now. It looks like 3.8GHz is very doable with a good cooler and 1.35V.
Zstream
3,395
277
A good cooler is not going to help that much. It is the ambient temp around the PC that is more crucial.
AdamK47
3,638
So what do you have your up to?
Zstream
3,395
277
No i7 here, running a 3.8-4.2ghz Wolfdale. I should have not upgraded from my e4500 and just went to i7.
AdamK47
3,638
Ambient temp isn't going to help much when the cooler doesn't move the heat from the processor to the ambient air fast enough. A better cooler will greatly help dissipate the heat from a Core i7 processor. Check this video out.
Zstream
3,395
277
I was under the assumption you are not using a stock cooler and using something midrange or like an ultra 120.
aigomorla
21,131
3,667
ROFL!
AdamK47
3,638
I'm not running stock. I have the Cooler Master V8. I'm replying to your statement of "A good cooler is not going to help that much. It is the ambient temp around the PC that is more crucial."
