Why do people keep saying this? Yes, the mobo will be slightly more $$, but the RAM is the same price. In fact, it is cheaper to buy four 2GB sticks (quad channel) than it is to buy two 4GB sticks (dual channel). So that arguement is not valid. Tripple channel was more expensive only because you have to buy special kits of 3. That is not going to be the case with quad channel.
how many times do I have to state 22nm for you to actually read it and understand ?
todays 2500-2600 are on 32nm
You are seriously borderline (radio edit) if you think intel is going to make a 4.4ghz 2700k as 22nm and have it similarly priced as 2600k. Here's how CPU's are binned: A newly fabbed CPU is connected to a special "tester" machine. This machine controls all of the pins to the CPU, and specially-written test programs are played onto the pins (with expected results). The clock and voltage are increased until the point of failure, and this determines which bin it makes.
The 2700k is being binned the same as the 2500 and 2600. Simply upping the clock isn't a trivial matter. While it may overclock to 4.4 easily, its not as easy to have a good yield for a 4.4ghz part. Since the 2700 will be binned the same as 2500/2600, its a near certainty that they A) not going to be 22nm B) be clocked any higher than a 100-200 mhz increment. Anything more than a 100mhz increment would likely have poor yields/profitability. This is speculation on my part, but i'm almost certain that 2700k will not exceed 4ghz turbo frequency.
http://www.anandtech.com/show/4757/intel-leaks-i72700k
Speculation from those in the know is that it will actually be a 3.9 ghz turbo, 3.5-3.6 base. Feel free to argue with every other website speculating the same thing with your broken english.
Exactly what I was thinking since the trends have been:
2500k - 3.3ghz/3.7ghz Turbo
2600k - 3.4ghz/3.8ghz Turbo
2700k - 3.5ghz/3.9ghz Turbo
This is not AMD where they do things that make no sense. ie- have a quad core Stock 4ghz with a 100mhz turbo and an 8100 with a 800mhz turboD:
only thing that can be exciting is if its a new stepping.
if not, yawn.
i7 2600K is crazy fast. i7 2700K for the same price will also be crazy fast. I'm not seeing a downside here. Want more performance now? Go x58.
X58 is slower, buddy. Westmere is faster in a few things, but that's very few. X58 also gulps juice like a teamster, and runs a lot hotter to boot.
Daimon
i7 970/980/990x slower than 2600K?
Daimon
Vice Admiral Lord Horatio Nelson said:Only numbers can annihilate.
Anandtech bench results show they trade back and forth at stock clocks, and you'll be hard-pressed to get a gulftown up to an OC'ed clockspeed that SB won't eclipse if given equal effort with the cooling setup and expertise.
In everything except for encoding and rendering, yes. Don't take my word for it, read a review or two.
Daimon.
slower in some applications, faster in others. For gaming 2600k is better. Overall, the 980x/990x are better.
A $1000 CPU should win every single benchmark, no questions asked.
They should release some more i5 'k' variants as well. It makes me wonder if they are going to also possibly phase out the 2500k and just leave 2700k and 2800k.
I only wished there 1155 ivys came out since I need a new laptop and hp has 30% off coupons since they are getting out of the pc market.
I would be surprised if HP released a Ivy Bridge laptop if they are looking to get out of the market. Doing any form of R&D for a new laptop on the way out the door does not strike me as smart business. But then the markets HP has been getting out of (and how) at a loss I find strange anyway.
