so an i5 4690k isnt worth the 230$ over my 4440?
awesome thanks man.. maybe a motherboard upgrade then so i can run faster ram.. is that worth it.. mine maxes out at ddr3 1600.. looking for best bang for my buck over what i currently have
+1. Are you using 3x 4gb sticks? If so you're ram configuration is slowing you down as you are not running in dual channel.
I think as long as the slot pairs, be they 1 and 2 or 1 and 3 or whatever, have the same size stick it'd be ok. Maybe not ideal but it's not likely a huge thing. If you're looking to upgrade something I'd put matching 4's in each slot myself.
