Greetings. I'm currently trying to optimize my cooling and airflow in my case.
System specs:
Opteron 170 overclocked to 2.4
Thermalright HR-01 heatsink with a Scythe S-Flex 1200 RPM
Asus A8N-SLI with TT copper heatpipe NB cooler
XFX 8600GTS OC with Zalman VF-900
WD SE16 250GB
all in the PC-7B Plus II-stock 120mm fans (rear exhaust, front intake)
Currently CPU idle temps are 37-38*C, load temps 46-50*C.
GPU-Idle 38*C load 45-48*C maybe a little higher.
I'm trying to keep it quiet but cool. I live in Phoenix, AZ, so it gets warm, but we usually have the A/C on.
Any suggestions on fans or better cooling? I removed the internal protection grill from the rear fan to try to get better flow. Didn't seem to change anything though.
System specs:
WD SE16 250GB
