Cooling for X6-FX 6300
not sure what to spend here throw me a few ideal ?
I am not sure what's the pricing on something good.. 60$ around that ? I won;t be doing any OC unless the cpu is worth OCing and the board can handle it.
I have this:
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=060891
And fan is not exceeding 1000RPMs in OCCT @4,2 GHZ
I guess this is a better cooler for better price if you can get rebate:
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=030429
http://www.frostytech.com/articleview.cfm?articleid=2721&page=4
13,9'C vs 19,9'C on 125W platform with comparable noise levels - Zalman is quieter by 3dB
What board are you using ?
OK, what board do you have or planing on buying ??
I was thinking of getting the below.
CPU - AMD X6 FX-6300 (95W) Six-Core Socket AM3+, 3.5GHz
CPU cooling - I need advice if you can point one out from the site above thanks.
Ram - ADATA XPG V1 Series Black 8GB (2x4GB) DDR3 1600MHz CL9 DIMMs (AX3U1600W4G9-DB)
Motherboard - ASRock 970 Extreme3 R2.0 Socket AM3+
But if that CPU OC well with a different board i would like to know.
This asrock has 5 Phase VRM under heatsink, while my asus only 4 without cooling (which causes VRM overheating and throttling in OCCT on default clocks!)
I have also MSI 760g-p43(fx) with 5 Phase VRM (without heatsink) which works great. FX6300 at 4,4GHz in OCCT without any issues.
I guess ASRock 970 Extreme3 is perfect match for the FX6300 and should have room for overclocking.
I will get teh asrock and see what it can do.
and for CPU cooling should I get something like this - > http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=060929
Before doing any oc ill obviously read ill run the computer for a week or so at default.
I bought a Corsair H60 water cooler from Canada Computers, for that exact CPU. It cost me $50 (yes, it was on sale).
It's so efficient - and so quiet! - I'd have a hard time recommending anything else.
Many people swear by the Cooler Master Hyper 212 EVO, but it wasn't a suitable option for me, because it didn't fit in my Bitfenix Outlaw case. I also have a Zalman CNPS10X Performa in another rig, cooling a Quad Phenom. Great cooler, too, but it's even bigger than the 212!
And, in the end, when the difference between the Performa and a watercooling kit is $15, why bother?
Looking at the watercooling kits - http://www.canadacomputers.com/index.php?cPath=8_135&bsort=0&brand=0&price=1&location=0 - the very first result shows you can get a ZALMAN LQ-310 for $40 (after rebate)... It seems to get really nice Newegg reviews, so I'd say go with it.
