Cooling for E6300
Yes, its a good choice. There are other good choices as well. Comes down to budget I think more than anything else assuming all the choices fit together nicely.
i already built my conroe system. however right now it is only running on stock cooling.
so i'm planning to get a zalman for overclocking.
How much of an overclock do you want? You may do well with an ArcticCooling Freezer 7 Pro for under $30. Not everyone needs $60 invested in a CPU HSF.
newegg doesnt' ship to canada.
canadian sites have artic freezer for about 50 -60. might as well get a 70 $ cnd Zalman.
Can any 1 verify this IF Zalman 9500 is compatiable with the P955-DS3 Gigabyte board? As in does it fit nicely
It's not a terribly imposing HSF. I would be very surprised if it had problems fitting in any board with a supported socket mount.
-phil
