Originally posted by: DerwenArtos12
Originally posted by: Rodknock
Well after almost a week without a computer I'm back😀
I received the Stacker 810, looks like it's going to do just fine. I'm on FrozenCPU right now, ordering a few things for the project. Here's the final parts list (major components only):
Dual Swiftech MCR220 radiators, both with internal reservoirs (going to order one now for the front, see what the size it is and if one would be able to fit on the back dual 120mm slot or if I need to get the one w/o the reservoir)
Dual Swiftech MCP655 pumps (price difference between these and the 355s is only 20 bucks, I figure why not step it up a bit?)
D-tek Fuzion CPU waterblock
Danger Den full-cover GPU waterblock (8800)
I'm still confused on what size fittings I need for the pumps, blocks, etc? 1/2", 3/8"? There's so many damned options.
First of all, i love frozen cpu and their customer service has always been great in my experiences, but their prices have been a little higher lately, I would suggest checking out sidewinder computers, SVC and jab-tech also. The MCP 655 is a great pump and I'm just now starting to hear about some longevity problems with the 355 plus, it won't need a top. Keep in mind that you can tune down the voltage on that 655 to prevent too much heat dump into your loop as they do get warmer than the 355. Since you are running a seperate CPU loop I would reccomend the accelerator nozles to tune performance even a bit more. You'll want to get 1/2" barbs with 7/16" ID tubing. You'll want to soak the tubing in hot water to soften in before you try and put it on the barbs to make it easier. Aigomorla likes to use KY, and who doesn't....
With the D-Tek you should use EK high flow barbs, danger den barbs with the dangerden and if you can, use the EK barbs on the radiators, not sure if they'll leak on the res' like they do on swiftech's blocks, any help here Aigomorla?
