- Apr 24, 2001
- 4,712
- 2
- 0
I just build a brand new pc and I used the Centurion 5 case. I put in those chassic cables (for the power and reset switch, hdd light..etc) but there are 2 small cables that are marked with a "+" and a "-" respectively. What are those 2 small cables for?? Is that the power led?? The documentation as usual with most pc hardware is piss poor and doesnt say what it is. On my motherboard manual (asus a8n-e) it says the power led is suppoed to be 3 pinned so I dont think that small + and - cables are it ..are they?
Also the centurion 5 case I have has that weird looking black cone thing on the side panel that is pretty much over the cpu fan/hs. Should I take that big thing out and replace it with a case fan (80mm I assume). If so, should that fan blow air in or out the case?
Thanks in advance to those that help.
