Galvanic corrosion (the type that occurs when a circuit exists between two dissimilar metals) does not require the presence of silicates to occur. Any electrolytic species will cause this corrosion. Silicates may catalyze the process, but so too would many other chemicals.Originally posted by: Texun
I don't have water cooling so my advice may not be worth squat but here goes...
I've read many others like jfrog who use a 50/50 premixed auto coolant with no problems. However, if you have two dissimilar metals in the cooling system I would make certain the coolant is silicate free or you risk corrosion. If you use any water at all make sure it is distilled.
I looked at various different engine coolants for my scooter, trying to find just one that would clearly state that it was totally silicate free. The only one that matched what I needed was Honda coolant at my local bike dealer.
If it were me doing the build and I wanted to go with engine coolant that's what I would look at first. It's pre-mixed, silicate free, and if it matters it's blue. It covers all the bases.... removed heat and does not corrode or leave calcium build up.
Yet the principles of operation are the same: remove heat, no corrosion, no growth of undesired life forms. Ethylene glycol is indeed a powerful antimicrobial agent, and relatively dilute solutions (I speculate 10-20% should be more than enough) should prevent the growth of any microbial life. Further, this would have minimal impact on the performance of the cooling loop. While it's true ethylene glycol has a lower thermal conductivity than water (by a factor of 3, IIRC), this property in solution will be dominated by the more abundant species: water. Further, ethylene glycol is more viscous, but adding a small amount of water to a lot of ethylene glycol and you get a solution with approximately the viscosity of water. Thus, a solution that is 80% water will have water-like viscous and thermal properties, with the antimicrobial benefit of ethylene glycol.Originally posted by: HardWarrior
Car engines and PC-based water coolers are very different environments.
Originally posted by: TheoPetro
so just go w/ 20% antifreeze and 80% H2O??? or 50/50 or all water. im running all tap water right now and not having any problems what so ever
You're right, it's very easy to say that, because it's true. Or do the laws of physics and thermodynamics apply differently in a car engine and a watercooling setup?Originally posted by: HardWarrior
It's easy to SAY that the "principles are the same", it's even possible to make shallow associations between the two respective environments without much trouble.
Yes, the entire cooling system in my automobile is comprised of rubber hoses and aluminum heat transfer surfaces. Amazingly, this is what I would probably build a watercooling system out of as well. So what's the difference?The truth, however, is that a combustion engine is a far more extreme environment. A water-cooler is a toy by comparison. For instance, a combustion engine is built to last for years, and is composed of materials that make that possible.
The principles of heat transfer are the same, regardless of the temperatures under consideration. So are pumping considerations. The only effect temperature has on the system is to vary the properties of the transfer fluid, depending on the stage of the loop, since we're not discussing phase change fluids.Another similarity, that in practice isn't really all that similar, is thermal management.
I didn't.A typicial water cooler never appoaches the operatiing temparature of an engine, yet people still toss fluids like Water-Wetter into their loops, even though it says on the bottle that its "wetting" properties activate at 200 degrees.
This isn't true. High temperatures often have the effect of increasing microbiotic growth rates. As I mentioned previously, ethylene glycol is toxic to any life forms that might try to grow in such a loop. Just to be sure I wasn't making this up, I asked my research group's microbiologist today and he said that's definitely the case.And last but not least, simply running an engine will sterilize any biotics present. PC water-cooling is, again, quite different.
Ethylene glycol is toxic. It doesn't wear out and it's not consumed as a function of its toxicity. Simply put, this stuff will not grow in a solution with any significant amount of EG in it.Originally posted by: HardWarrior
Perhaps, but that's the point Oroo. No one seems to know for sure. And remember, anti-freeze is designed to alter the freezing point of a given liquid, not act as an algaecide. So even if it does just happen to kill things how long does it reliably do so, and at what level of efficacy?
In any case, the point is that temperature is not an important factor in determining the likelihood of growth in a system containing ethylene glycol.Originally posted by: NINaudio
Unless we're talking about microbitoics that grow near hydrothermal vents, there are not many forms that would survive in a constant temperature of 180°F +. True, elevated temperatures can often speed growth of said organisms, but there is a point where the temperatures start to hinder growth and development.
Main pipes may be different with respect to mineral deposition as the shear rates and velocities within the pipe are higher than for a similar watercooling system.Originally posted by: Greenman
I've pulled copper water pipes that were 40 years old with no deposits on the inside. I've never seen anything more than a very thin layer of crud, even in areas with very poor water quality.
