Dye
Regarding the dye I linked to above, will such UV coolant dyes alter the color of the fluid only under UV lighting, or will the color change be apparent even without UV lighting.
I ask as I was planning to purchase some UV coolant dye to add to my car when I do a flush/fill of the system with Zerex G-05, which is nearly clear when mixed 50/50. I was looking to add some dye to the fluid for easier fluid level checks, but was wondering if the dye would be effective without UV lighting.
Also, does anyone know of cheaper sources for UV Coolant dyes?
Thanks.
Thanks.
