moonbogg
idiots? 😛
Awww come on. Its 5ghz though.
idiots? 😛
Using SPECint for desktop now ?? 😛
Im sure at the same clocks when OCed the difference will be less than 20% :whiste:
This must be the only benchmark that will show 291% performance difference, im sure they tried hard to find the one benchmark to rule them all, 😛
ps: also completely irrelevant for desktop usage, im sure they could show a nice performance gain going from Core 2 Quad to Devils Canyon by using Cinebench or x264 with AVX but noooo they had to use SPECint 😵
Markets are segmented by more than just intended use. If specifications are true, not only would the 5820k be more expensive than DC and require a platform/RAM upgrade for current Haswell users, it will have limited PCI-E lanes for graphics cards.
you really have to change to Z97 mobo too to get full potential of the 4790k. it would be beyond silly to change all of that out for what result in a miniscule gain even with a good ocing 4790k. at this point you should at the very minimum wait for Broadwell K. the 4790k is really only for those on older i5 or really old i7 setups that have been putting off getting a 3770k or 4770k.To be honest I have a 4770k and Im thinking of getting this CPU. Mainly beacause my haswell cant go over 4.4 Ghz and it needs the whole 120v from the wall outlet to do so. Still I want to see how it performs first before taking the swing.
Based on rumors, the Core i7-5820K will still have 1x16+ 1x8 + 1x4 lanes, which is still more than the 16 offered by 4790K.
I have seen many posts now about high DDR4 prices but has anyone seen DDR4 in retail yet to confirm this?
Buyers will pay a 30 percent or higher premium for DDR4 memory compared to DDR3 next year, though the price differential is expected to decline to around 10 percent in 2015, Howard said. Starting in 2016, DDR4 shipments will outpace DDR3, which will ultimately fade away just like the older DDR2 memory.
Paranoia? Try common sense.The DDR4 pricing paranoia is nonsense. If a 16GB kit of premium DD3 goes for $250, maybe you'll pay $350 for the same in DDR4. If you're buying HW-E, you're not going to care.
DDR4 will absolutely be more expensive,
and likely slower than current DDR3, until it matures and early adopters pay some R&D tax.
It also has a 700mhz slower base frequency, almost double the TDP, and cannot be dropped into a current platform like 1150.
The cost of a X99 board is probably not competitive with a Z87 or Z97 chipset, either.
Frankly, they aren't competing with each other.
So I have a 3570k stable at 4.8GHz all four cores on corsair water. This sounds tempting to me. I picked the 3570 over the 3770 because I heard they O/C better due to lack of HT.
I'm going to assume (hopefully not a poor assumption) that an Intel CPU ships with some headroom. I don't think this is the kind of company that ships out a product that is clocked to its maximum potential. If they were they would have shipped a 4GHz Pentium 4.
When reviews come out and those show it can hit 5GHz then this is a no brainer upgrade for me. HT plus improved IPC and I guess a little higher clock speed.
If on the other hand this does not hit 4.8GHz, I'm not going to bother.
BTW, how long do you guys think it'll be before we start seeing some OC'ed benchmarks?
Call me crazy, but $100 is a lot to me. If I saved up for enough for Haswell-E, I'd definitely care about an added $100.
But why would you spend $100 for something that will add next to zero value for most workloads? Heck, just about everyone has DDR3 at this point, so why not reuse it?
Hopefully the reviews are good as while I like/want to upgrade I can't justify it if there is next to no real benifet for me. Do you think there will be much of a reason to go from a happy stable 2600K @ 4.6Ghz to the 4790K?
As you saw with Watch Dogs and VRAM situation, all it takes is just 1-2 games to change the landscape for PC gamers. It will take just 1-2 high profile games like Witcher 3 or the Division or BF5 to take full advantage of 6 cores and it will make the 5820 @ 4.5ghz worth it over 4790K @ 5Ghz.
I wouldn't discount the 5820 just yet.
Huh? I'm not following you. I'm talking about DDR3 vs. DDR4, not about core count.If you wouldn't pay $100 more to go from 4 to 6 cores, then of course HW-E platform is not for you. In that case, if $80-100 is a lot to you, why would you get an i7 4790K over 4690K?
How much you want to bet that every single Haswell Refresh chip has the exact same "new and improved next-gen TIM" under the IHS?
I'd be absolutely surprised if that wasn't the case.
That's an interesting assertion. The substrate underside on the refresh HSW processors don't have the additional capacitors, and they use different substrates (minor differences on the underside can be seen in the "capacitor rectangle." The way things appear to me is that the new "K" SKUs are on a separate manufacturing line. They could definitely be using the "NGTIM" on the refresh SKUs, but I wager that they aren't.How much you want to bet that every single Haswell Refresh chip has the exact same "new and improved next-gen TIM" under the IHS?
DDR3's actually relatively expensive right now. The oft-cited 30% premium figure was from IHS, and those numbers were polled before the Hynix fire had happened, and the resulting price hike still hasn't subsided.Because if you want to run X99 you need DDR4.
$100 is not much considering the total platform upgrade cost and it sounds like it will only possibly be a 30% premium over DDR3, that's peanuts given how cheap DDR3 is.
Pfft. All of this Haswell-E and DDR4 sidebar. If you think DDR4 is going to be cheap, keep thinking that. Right now 16GB DDR4 kits are going for near 600$. It isn't hard to find prices. Google it. If you think it's going to be remotely reasonable, well, having seen like 5 DRAM launches in prior years. If you've watched prior DRAM launches, you know what's up: they always are overpriced and underperforming at launch. In fact, at launch, every new DRAM technology is priced into the stratosphere at LAUNCH. There has never been an exception. Period. But what will happen is prices will slowly normalize and speeds will increase over the next year or two after launch of the intel platform using it. But, you say, an intel slide told you that prices won't be expensive. Okay. Believe that. They said the same thing about RDRAM. "It wont' have a significant price premium". LOL. Hoooooooooboy did that not happen.
DDR4 will not be an exception. But by all means, keep thinking otherwise. I'll be looking on with amusement when Haswell-E does launch and everyone and their brother is whining about launch DDR 4 prices. You can buy them for servers NOW. 16GB for 600$ of DDR4 at slower rated speeds than comparable DDR3. Have fun with that.
Anyway, Haswell-E will be a great platform for those wanting hexa core or 8 core CPUs. The 5820K should be a great chip. However, make no mistake, DDR4 will be a significant setback for many wanting to go the HEDT route. That will eventually change, but it's going to take at least a year after Haswell-E launches for prices to not be stupid. Most prior DRAM launches took more than a year for prices to go into the sane realm. DDR3 wasn't cheap at launch. Same crap happened. Same crap will happen again.
Then again, does it really freakin matter? Probably not. People adopting the HEDT platform aren't penny pinchers anyway. So in the end it doesn't make a difference. Many guys buying into HEDT area already spending 400$ on a mobo and 600$ on a CPU. Will 500$ for DRAM matter to these guys? Heck no. DDR4 is going to be expensive for the budget minded guys, but most HEDT users simply won't care and will buy it anyway despite the cost.
