[Coolaler] AMD Piledriver FX Engineering Sample Benchmarks
Guys remember that the PD CPU being tested is the lowest tier 8 core. There are actually 2 more steps above this CPU. So compare to a 2500k at most IMO. If they manage to fix the power consumption problem while gaining an overall 10% in singlethreaded performance, I think it will be good, especially for upcoming Windows 8.
If they can do that, it won't be a bad chip at all. Now Windows 8.... It's going to be a monumental task to prevent it from going over like Unity and Gnome Shell 3. Looks like the iPhone generation of GUI developers is upon us for the desktop (Lord help us).
So an 8-core PD is roughly equivalent to the 6-core PhII and everyone is singing praises? Am I missing something? That is per the CB screenshot where the PD is slightly below in performance, but also slightly lower in freq. And that's with a 125w TDP.
I am extremely skeptical that these scores would be indicative of the final PD chips. Looking at the 3dMark06 scores, those benchmarks are claiming a score of 4986 for a 3.3ghz PD, yet a 8120 @3.1+turbo scores 5452, and an 8150 scores 5900.
Smells pretty fishy to me.
what's more interesting is how high does it overclock and it's O/Ced performance and power consumption. BD was a massive clocker but also very power hungry.
MOAR benchmarks
Why does the CPU-Z say Zambezi instead of Vishera?
Fishy indeed. FX8120 scores 5450 in 3dmark06 CPU subtest. If this ES was indeed PD based it is slower than Zambezi which doesn't make any sense. Note that this ES has 3.3/3.7Ghz stock/all cores Turbo which is higher than what FX8120 has (3.1/3.4Ghz stock/all cores Turbo). Even 5800K scores 4300pts in 3dmark06 and it has only 2 modules versus 4 in this ES.
Also superpi 32M score is worse than FX8120's score (both at stock). This ES has higher one core Turbo since both stock and full core Turbo are higher(should be 100-200Mhz higher), so this is another anomaly.
Are these pi numbers good or bad?
24 minutes when a 8150 does it at stock @ 19,3 minutes yes.
It's absolutely horrible.
Anyone extremely scared about how many blind fanbois see that coolaler thread as the holy grail for AMD @ overclock.net?
Damn it's scary.
(Granted we have our TSX\AVX2 fanbois too here, but atleast generally we like to use some logical theorectical max\fact as evidence).
Ok . Good post . 1 question tho . whats windows 8 going to do for AMD pile ? Also did you notice that this 3rd tear cpu was using 124 watts. Intels are 95 watts . So If intel wanted to they could bring out a 125 watt. IB./ For some reason everyone wants to compare to intels last generation yet again . really a sad lot.
You honestly think CPU-Z is reporting correctly?
From these benchmarks it seems that AMD lost all the design and technical documents on Piledriver after releasing Trinity and resorted to putting their engineering team in a cage with an electron microscope, a Trinity chip, lifetime supply of Jaegermeister and a parrot. In the end, they produced something similar to a Piledriver module if you squint a bit and the parrot is now the lead engineer due to winning a drunken engineering swearoff.
That or this ES just might not be the final one 😉
