Cool optical illusions with color!
Well the inverse of hot pink is lime green, your eyes make up for a sudden lack of the hot pink with a lime green, something to do with the color vision receptors
the eye primarily senses changes. If something isn't moving or changing on the retina, it doesn't appear. This is why you don't normally see all the blood vessels and nerve fibres in your eye (which due to a rather spectacularly bad design, actually run directly in front of the retina).
The receptors adapt to the presence of the pink dots within a few seconds, so that they appear a neutral grey. However, the rapidly moving grey dot remains visible because it is moving. However, because the eye has adapted to the pink, the grey looks green (it's the complement of pink).
Because the eyes always make very slight movememnts, the pink dots need to have blurred edges, so that slight movements on the retina don't cause them to reappear. A sharp edge which moved even very slighlty would be very obvious.
You don't even need a printed (or on-screen) illusion for this effect to be visible. Simply focus intently on one object spot, somewhere in your vision. For optimal effect, it's best to use one eye only, and hold it still (for best results, apply very gentle pressure through an eyelid to keep it absolutely still). Within a few seconds, everything in view will disappear, but as soon as you move your eye, it will reappear again.
Originally posted by: newnameman
Originally posted by: klah
This is why I only trust computers...
For number 3, both of the cross pieces look like grey to me 😕
Have you taken a Ishihara test?
Yeah, and I passed those just fine. But I still don't see the yellow. 🙁
I don't see yellow, either. What's the deal? My son sees dark grey on the left and yellow on the right. He sees both the same mid grey color when mask is applied. I see dark grey on the left, and light grey on the right, until mask is applied, then I see both as mid grey. All other illusions function as intended. 😕
Edit: Just passed the Ishihara Test for Color Blindness
Originally posted by: Azndude51
Wow, my eyes must be messed up because on the third one, the left one still looks gray and the right one still looks yellow after I apply the mask. The circling dot one works for me though.
Yea its kinda like that for me... they both look gray, but the right one still has like a yellowish tint to it.
