Any ideas? I am not up to speed on cases. 😛
Also, Besides the Mach II..I am H2o cooled. So I need a case with some nice top bays so I can put a rad in one and cut 2 120mm hoels in the top.
I think a Antec SuperLanboy would fit nicely on top of a phase-change unit. It is a fairly small case and made of aluminum so if you wanted to go to lan parties you'd be less likely to get a hernia.
